After climbing to the summit of Pizol (HB/SG-003) I went to the top of Schwarze Hörner (HB/SG-008). On this summit I had only limited space and on SG-008 no summit cross to use as an antenna pole. Probably my weak signal is the reason of the wrong ref on the Spot (Thank you anyway Frid for spotting!). So I do appologize and thanks for all the QSOs.
Correct ref of my 2nd summit: HB/SG-008.
73’s Jürg
