HB/BS-001 Valid Summit?
Yesterday (08/09/18) I chased HB9/F5HTR/P on HB/BS-001. This summit ref does not appear to be valid? Perhaps I made a mistake in copying down the ref?
73 Andrew G4AFI
When in doubt look in the database.
http://www.sotadata.org.uk/summitReport.aspx
Enter as much of the name or ref you know and see what comes back. Entering BS-001 lists
6 or so summits including HB/BS-001 and click that shows the full history of this summit
Scoring History
From	        To       	Score	Bonus
01/Aug/2005	31/May/2018	1	No
So there you go, no longer a valid summit. Only activations from 1-aug-2005 to 31-may-2018 can be enter to the DB.
Thanks for that Andy. Clearly not valid.
73 Andrew
Andrew
Bob activated this REF yesterday.
I told him it is not valid summit :wink:
73 QRO
Hi Folks,
It was a lot of fun when i realised that is was not anymore a valid summit.
As i did not check nothing before to go the summit, I made about 30 qso and when i wanted to spot myself, i realized that this summit was cancelled last update !
By the way, i had a lot of pleasure to qso you all, weather was just perfect !
Sorry for this zero pointer ! Next time i will check database !!!
best regards to all
F5HTR
No problem. Thanks for the contact. Always nice to work you in the SOTA pile-up with my qrp.
73, Tonnie de PA9CW.
Why zero ?
We logged S2S from OE/OO-287 which finally counts for you as chaser.
So, no zero :wink:
73, Jarek SP9MA
P.S.
Interested how was possible to switch on the spot by another OM, the spot is still visible on sotawatch :wink:
Spots via the Spotlite interface do not currently check validity of the summit. Many apps use this interface.
Yep ! you are right Jarek ! c u soon
