GW/NW-070 Great Orme Report
Activation report: 16th March 2007 Great Orme GW/NW-070
Winter bonus over and it looked like there was not much to chase. Mike GW0DSP had been itching to activate for some time and his tentative attempt to go solo on Hope Mountain had been curtailed by the fact that he would have had to wade to the summit through knee high mud. A few tests with a two metre vertical on a mag mount attached to a farm gate got encouraging results and made him even more determined.
The sun was shining and stepping outside it seemed quite mild for the time of year, so when Mike suggested we activate Great Orme I was all for it.
As many of you know I broke my ankle in January and my right foot is still very swollen, however I had managed to squeeze my foot into an old pair of boots for the first time a few days before, and I was determined to give it a go. Mike also has problems a serious and permanent back injury and so Great Orme seemed like a good choice for the two old crocks limping slowly from the car park. It was quite a contrast to my last activation of NW-070 when on a warm sunny I did a circular walk around the Orme from the car park to the bottom and back before activating.
As usual things conspired against us from the start, phone calls, visitors, I needed to be back in time to baby sit the grand daughter, road works and of course the weather. Then I found I couldn’t get the 2/70 quad we had intended to use into Mikes car without disassembling it. The closer we got the darker sky got and when we got out of Mike’s car on the Orme there was a stiff icy breeze blowing.
We set up station in the lee of the wind and used bungees around the trig point to hold up a lower than usual mast for the dual band vertical and the multi-band dipole. Something up there must have changed on the transmitters since I last activated because 2 metres and 70 cm were completely blotted out by S9+60dB of mush. On the previous occasion I had only had problems with desensing during a single contact with Dave G6LKB in the Lake District and made contacts on both 2 and 70 in to the Isle of Man. This time there was no such luck for Mike and despite trying different radios nothing could be heard over the QRM on 2 or 70 FM or ssb.
I had my suspicions 5mHz was not going to be very good either, as the last few days had been some of the worst for inter UK in a while, but I got a pleasant surprise when I heard Rob G4RQJ/P activating Top o’Seleside G/LD-048 on Fox Echo (5.3985 usb) as soon as I turned on. Getting in between the base stations wasn’t happening until John GW4BVE left a gap as he checked the F2 critical frequency and I squeezed in, then with chaser points in the bag I QSYed down to Fox Lima (5.3715 usb). The band conditions on 5mHz seemed to contradict the data John had from the Internet and most reception reports were poor, received signals tended to be better but not what I have come to expect. Everything we heard we worked with the exception of Graham G4JZF who was not moving the metre but still perfectly readable but we just couldn’t get the report back. :o( I guess there were more out there that couldn’t hear us either but at least the summit was well qualified.
After 5mHz Mike tried CW on 40 metres but finding a free spot meant moving away from 7.032 and his CQs went unanswered for about ten minutes until large raindrops started falling and we decided to pack up and make our way back to the car.
Dismantling the mast the wind went from stiff breeze to hurricane in a nanosecond and nearly knocked both Mike and I off our feet. Boy, were we glad to be back in the car! All in all an enjoyable day, fraught with disappointment and frustration, frozen blue and wind burned, but I really enjoyed it.
Learning points:
          * There were many learning points today but the main one is a still greater appreciation for the ‘serious activators’, I really do not understand how you guys do it.
          * If you are thinking of activating Great Orme take some filters.
Thanks to everyone who worked us and to everyone who listened but could not hear us. Maybe next summit we will get better weather and propagation and only have to moan about how long it took entering all the contacts in the database. :o)
Regards Steve GW7AAV and Mike GW0DSP
http://gw7aav.googlepages.com
Photos on Flikr**
In reply to GW7AAV:
Steve
I saw Mike was coming on and returned to 40m from 20 to see if I could hear him from my hill. By chance I ended up working Zoli instead. I tuned around several times afterwards listening for Mike but no luck. Next time perhaps.
Richard
G3CWI
In reply to G3CWI:
Hi Richard,
I know Mike would have liked to have spent more time trying and I wanted to try 7115/7060 ssb but the rain finished it for us. Maybe next time I will be able to work you on the key too, I have nearly got the letters learned, so there is light at the end of the tunnel.
In reply to GW7AAV:
(Some pictures from today’s activation now on Flickr)
I would like to add my thanks to the five stations that I worked today on 5 megs, hence qualifying my first time activation on GW/NW-070 Great Orme, but especially to Rob G4RQJ/P for my first ever activation contact, which also happened to be my first s2s.
Apologies to anyone who was listening for me on vhf/uhf, but it was out of my hands, the emissions from the radio mast “killed” it.
Had the wind eased a bit I would have had a wander around the activation area looking for a null from the radio mast.
Also apologies for the short time trying on 40M cw, I only managed about 10 minutes, but there was heavy qrm from EU on the usual frequencies and the weather turned sour very quickly.
I echo Steve’s admiration for the regular activators, your efforts are highly appreciated by myself having now experienced the way the weather changed today on an “easy” summit, I genuinely salute every last one of you and will give more thought to you when I’m sitting in the luxury of an armchair, chasing from my centrally heated shack.
If I get lucky, I’ll drag Steve out again soon and activate Hope mountain.
