Apologies to the chasers who were calling me on G/SP-013 Gun, this morning. The wind was almost gale force and the 2m bunny ear antenna, simply dissapeared. My cap and two pages of the log book followed it and that’s when I went qrt.
Thanks to Bob G6ODU for the spot. Only 5 contacts made. One contact, Mark MW0TTK, tells me he has lost his HF antenna. So much for the wonderful British summer
It wasn’t too bad on Foel Fenli yesterday. The wind did lift me up once when sat down and moved my vast bulk about 4ft across the ground but the ribbon feeder J-pole / fishing rod survived the breeze. Only the bottom 2 sections up though. Probably a constant 25mph with big gusts.
Sorry to hear of your troubles Mike. At least you got your hat back.
Bad luck, Mike, but I bet it’s the last time you go out in a hurricane
remnant! I did it once, Hurricane Charlie, 1988 - never again!
Tell me about it, Brian. The funny thing was I was calling CQ and couldn’t understand why no-one was coming back. It was only after about 5 minutes, I looked up and noticed the antenna had blown away!
Anyhow, if anyone is interested in a single bunny ear, dipole antenna, my email address on qrz.com is good
The wind was pretty ferocious on G/LD-025 Seatallan too! At least there is a windbreak shelter at the top, though it was hardly possible to get to it from the trig point. Once in the shelter things weren’t too bad, and we managed a reasonably comfortable VHF-only activation on the rucksack antenna. No chance of getting an HF antenna up on this one! Getting down was as hard work as going up!
On my return home from G/SP-013, I chased G3WFK/P up on G/SP-004 Shining Tor, this morning. He started off with a 3 element beam, but didn’t finish up with one.
… G3WFK/P up on G/SP-004 Shining Tor, this morning. He started off with a 3 element beam, but didn’t finish up with one.
One of my favourite QSL cards is from a GM whose card states “if your antenna system did not blow down last winter, it wasn’t large enough!”. Maybe we need a similar caption for SOTA QSLs when operating under adverse conditions.
Anybody been up GW/SW-003 - Lovely shelter cairn up there, however when 2E0BTR, M0MYA and I went up their in February of this year, I did not expect wind as fast and as cold as that.
Sat in the shelter cairn, some how got the 7m fishing pole up and the 4m slim jim! The only way to stop it from blowing down the mountain was to sit with it between my back and the wall of the cairn! Still managed to qualify exclusively on 4m FM, easy to say I did not hang around to have a go on 23cm!
