Just found this site, which has some impressive mountain panoramas: http://www.mountainpanoramas.com - might be of interest to some…
Rob DM1CM
Rob DM1CM
In reply to DM1CM:
Thanks for this Rob. The view from GM/NS-004 An Teallach - Bidein a’Ghlas Thuill has certainly whetted my appetite for getting back up onto higher ground.
73, Gerald G4OIG
In reply to DM1CM:
Great site Rob. I have a few 360 degrees summit shots myself and maybe if they are good enough they might be published?
Jack (;>J
GM4COX
In reply to DM1CM:
http://www.mountainpanoramas.com - might be of interest to some…Rob DM1CM
hello Rob
many thanks for this site. fabulous panoramas, the best I have seen .
alain
In reply to GM4COX:
Jack, they certainly do accept stitched panos for publication - go to Mountainpanoramas - Publish - Mountain / Panorama / Panoramics / Panoramen / 360 / Alpenpanoramen / Alpenpanorama / Berg / Alpen / Bergpanorama and follow the instructions. Good luck, I know I’m not alone in wanting to see some good Scottish panoramas - as long as they’re not 360° views of horizontal rain!
Rob DM1CM
In reply to DM1CM:
Hi again Rob!
The only problem I have is SOTA masts coming into the foreground of some of my shots - hi!
Will try and put some non-rainy ones on for you - hi hi!
Jack (;>J
GM4COX
