Thanks to the excellent checking facilities built into the database I am able to report the following errors in Chasers logs after submitting my logs for the GI/MM Tour this week when I was hosted by GI4ONL in the Mountains of Mourne:
07 AUGUST:
GI/MM-010 DL3HXX LOGGED GI4ONL/P IN ERROR
GI/MM-010 OE6GND NOT IN LOG
GI/MM-010 EA1DFP NOT IN LOG
GI/MM-010 DF5WA LOGGED GI4OBK/P AS GI4OBU/P IN ERROR
GI/MM-009 NO ERRORS FOUND
GI/MM-008 MI0RTY INCORRECT TIME LOGGED 1520Z (SHOULD BE 1420Z)
08 AUGUST:
GI/MM-006 DL8DXL LOGGED GI4ONL/P IN ERROR
GI/MM-003 NO ERRORS FOUND
GI/MM-014 NO ERRORS FOUND
09 AUGUST
GI/MM-004 DL8DXL LOGGED GI4ONL/P IN ERROR
GI/MM-004 PA0ALW LOGGED GI4ONL/P IN ERROR
GI/MM-004 G0VWP NOT IN LOG
GI/MM-005 NO ERRORS FOUND
GI/MM-007 NO ERRORS FOUND
Please correct or delete your log entry - I will check the database again in a weeks time and if logs not corrected I will try to make contact with you via personal message.
73 Phil G(I)4OBK/P
