Aaaahh!
I activated my first GI on Tuesday. I forgot my log book (my wife’s tolerance levels were already low as I fumbled around getting dressed before dawn, so I was under pressure to go without waking the in-laws). No problem, I’ve recorded the log on my phone before in similar circumstances. It was a beautiful sunrise looking over Belfast and a fine morning to be out in between the endless storms we’ve been suffering, though a bit windy!
Settled down just now to enter the log onto the database to find absolutely nothing after the summit name and date
I was active between about 0915 and 1010. I worked EA2IF first on 20m with difficulty as apparently my audio was poor. After fiddling without effect I QSY’d to 40m with much better results. I can remember a few of the regular British chasers I worked but have no idea of the times. There was a DK7, a PA0, a couple of Spanish stations and a host of English call signs. If anyone can help by sending me their log of when they worked me, I would be very grateful.
HNY all and thank you in hope
This is probably not complete, as it relies on chasers to have already entered their logs. Nonetheless, it may be of use.
The following QSOs were logged for GI/MM-010 (Slieve Croob) on 29/Dec/2015:
Time Chaser Activator Summit Ref. Summit Name Band Mode
09:24z EA2IF GI6PJZ/P GI/MM-010 Slieve Croob 14MHz SSB
09:38z G4OBK GI6PJZ/P GI/MM-010 Slieve Croob 7MHz SSB
09:38z PA7ZEE GI6PJZ/P GI/MM-010 Slieve Croob 7MHz SSB
09:40z G0VWP GI6PJZ/P GI/MM-010 Slieve Croob 7MHz SSB
09:41z G0RQL GI6PJZ/P GI/MM-010 Slieve Croob 7MHz SSB
09:43z M0IML GI6PJZ/P GI/MM-010 Slieve Croob 7MHz SSB
09:43z M3FEH GI6PJZ/P GI/MM-010 Slieve Croob 7MHz SSB
09:43z DK7ZH GI6PJZ/P GI/MM-010 Slieve Croob 7MHz SSB
09:44z M0MDA GI6PJZ/P GI/MM-010 Slieve Croob 7MHz SSB
09:45z EA2CKX GI6PJZ/P GI/MM-010 Slieve Croob 7MHz SSB
It is possible to generate this yourself. Simply log on, start the process of entering the activation, and enter that bit you can remember - or something false that you can delete later. Now there is an activation in your activator log you can use the “Show who chased me” feature added this last year.
