Is there a way to display a list of summits on a Scottish island? All island summits are in the same region GM/SI but I only want to see those on the Isle of Mull. The list is in height order but doesn’t say which island. I can zoom into Mull on SOTA maps so do I have to go through these one by one and cross reference to the list?
No
There are some islands in SS not SI. Ask the Alan Dawson why as he made the list.
Yes. But you can use the range function to only show the summits on Mull.
That’s great, thanks. Is that auto generated or did you do it manually?
Ok, I see how you did it.
Mark polygon and search for summits:
Download csv file of data:
SummitCode | AssocName | AssocCode | RegionName | RegionCode | SummitName | AltMeters | AltFeet | DistanceKm | DistanceMiles | ForwardBearing | Latitude | Longitude | Points | ActivationCount | ActivationDate | ActivationCall |
GM/SI-001 | Scotland | GM | Scottish Islands | SI | Sgurr Alasdair | 993 | 3257 | 0 | 0 | 0 | 57.2068 | -6.2259 | 6 | 2 | 02/07/2011 | MM6YCJ/P |
GM/SI-002 | Scotland | GM | Scottish Islands | SI | Sgurr Dearg - Inaccessible Pinnacle | 986 | 3234 | 0 | 0 | 0 | 57.2128 | -6.2349 | 6 | 2 | 02/07/2011 | MM6YCJ/P |
GM/SI-004 | Scotland | GM | Scottish Islands | SI | Sgurr nan Gillean | 965 | 3167 | 0 | 0 | 0 | 57.2484 | -6.1925 | 6 | 3 | 03/06/2012 | MM3WJZ/P |
GM/SI-005 | Scotland | GM | Scottish Islands | SI | Bla Bheinn (Blaven) | 928 | 3046 | 0 | 0 | 0 | 57.2193 | -6.0931 | 6 | 1 | 31/05/2012 | MM3WJZ/P |
GM/SI-010 | Scotland | GM | Scottish Islands | SI | Garbh-bheinn | 808 | 2650 | 0 | 0 | 0 | 57.2328 | -6.0929 | 4 | 1 | 01/06/2012 | MM3WJZ/P |
GM/SI-015 | Scotland | GM | Scottish Islands | SI | Glamaig - Sgurr Mhairi | 775 | 2542 | 0 | 0 | 0 | 57.2928 | -6.1278 | 4 | 2 | 08/09/2014 | GM1INK/P |
GM/SI-020 | Scotland | GM | Scottish Islands | SI | Sgurr na Coinnich | 739 | 2424 | 0 | 0 | 0 | 57.2357 | -5.7102 | 4 | 1 | 09/09/2012 | MM0YCJ/P |
GM/SI-021 | Scotland | GM | Scottish Islands | SI | Marsco | 736 | 2414 | 0 | 0 | 0 | 57.2494 | -6.1346 | 4 | 2 | 10/07/2013 | GM4UXH/P |
GM/SI-023 | Scotland | GM | Scottish Islands | SI | Beinn na Caillich | 733 | 2405 | 0 | 0 | 0 | 57.2424 | -5.696 | 4 | 1 | 09/09/2012 | MM0YCJ/P |
GM/SI-024 | Scotland | GM | Scottish Islands | SI | Beinn na Caillich | 732 | 2403 | 0 | 0 | 0 | 57.2374 | -5.9774 | 4 | 1 | 29/06/2014 | MM0YCJ/P |
GM/SI-025 | Scotland | GM | Scottish Islands | SI | Beinn Dearg Mhor | 731 | 2398 | 0 | 0 | 0 | 57.2797 | -6.1164 | 4 | 1 | 14/08/2007 | MM0DHY/P |
GM/SI-028 | Scotland | GM | Scottish Islands | SI | The Storr | 719 | 2358 | 0 | 0 | 0 | 57.5068 | -6.1838 | 4 | 6 | 01/07/2016 | MM3ZCB/P |
GM/SI-030 | Scotland | GM | Scottish Islands | SI | Beinn Dearg Mhor | 709 | 2326 | 0 | 0 | 0 | 57.2322 | -6 | 4 | 1 | 28/06/2014 | MM0YCJ/P |
GM/SI-032 | Scotland | GM | Scottish Islands | SI | Belig | 702 | 2303 | 0 | 0 | 0 | 57.2406 | -6.0739 | 4 | 1 | 25/05/2014 | MM0YCJ/P |
GM/SI-037 | Scotland | GM | Scottish Islands | SI | Hartaval | 668 | 2192 | 0 | 0 | 0 | 57.5158 | -6.2099 | 2 | 2 | 26/06/2012 | GM4UXH/P |
GM/SI-041 | Scotland | GM | Scottish Islands | SI | Ben Aslak | 610 | 2000 | 0 | 0 | 0 | 57.2074 | -5.7256 | 2 | 1 | 08/07/2013 | GM4UXH/P |
GM/SI-048 | Scotland | GM | Scottish Islands | SI | Ben na Cro | 572 | 1878 | 0 | 0 | 0 | 57.2438 | -6.0311 | 2 | 2 | 06/05/2014 | MM/DL8DBW/P |
GM/SI-051 | Scotland | GM | Scottish Islands | SI | Glas Bheinn Mhor | 570 | 1870 | 0 | 0 | 0 | 57.2573 | -6.0591 | 2 | 1 | 30/01/2008 | GM1INK/P |
GM/SI-054 | Scotland | GM | Scottish Islands | SI | Beinn na Seamraig | 561 | 1841 | 0 | 0 | 0 | 57.1946 | -5.7607 | 2 | 1 | 09/07/2013 | GM4UXH/P |
GM/SI-057 | Scotland | GM | Scottish Islands | SI | Ben Dearg | 552 | 1812 | 0 | 0 | 0 | 57.4735 | -6.21 | 2 | 1 | 15/08/2006 | MM0DHY/P |
GM/SI-058 | Scotland | GM | Scottish Islands | SI | Meall na Suiramach | 543 | 1781 | 0 | 0 | 0 | 57.6429 | -6.2816 | 2 | 11 | 28/06/2016 | MM3ZCB/P |
GM/SI-068 | Scotland | GM | Scottish Islands | SI | Sgurr na Stri | 497 | 1631 | 0 | 0 | 0 | 57.1961 | -6.1419 | 1 | 1 | 26/06/2009 | GM0IJZ/P |
GM/SI-070 | Scotland | GM | Scottish Islands | SI | Ruadh Stac | 493 | 1619 | 0 | 0 | 0 | 57.2328 | -6.1195 | 1 | 1 | 29/05/2016 | MM0YCJ/P |
GM/SI-074 | Scotland | GM | Scottish Islands | SI | Healabhal Bheag | 488 | 1601 | 0 | 0 | 0 | 57.3854 | -6.6196 | 1 | 3 | 24/06/2012 | GM4UXH/P |
GM/SI-079 | Scotland | GM | Scottish Islands | SI | Healabhal Mhor | 468 | 1535 | 0 | 0 | 0 | 57.4056 | -6.6321 | 1 | 1 | 03/09/2009 | GM4MD/P |
GM/SI-081 | Scotland | GM | Scottish Islands | SI | Bioda Buidhe | 466 | 1530 | 0 | 0 | 0 | 57.6147 | -6.29 | 1 | 7 | 28/06/2016 | MM3ZCB/P |
GM/SI-082 | Scotland | GM | Scottish Islands | SI | Beinn a’Bhraghad | 461 | 1512 | 0 | 0 | 0 | 57.2458 | -6.2968 | 1 | 1 | 27/08/2011 | GM4WSB/P |
GM/SI-089 | Scotland | GM | Scottish Islands | SI | Ben Lee | 445 | 1460 | 0 | 0 | 0 | 57.3235 | -6.1512 | 1 | 1 | 02/10/2013 | GM4MD/P |
GM/SI-090 | Scotland | GM | Scottish Islands | SI | Beinn Bhreac | 445 | 1460 | 0 | 0 | 0 | 57.2536 | -6.4072 | 1 | 2 | 27/06/2016 | MM3ZCB/P |
GM/SI-092 | Scotland | GM | Scottish Islands | SI | Dun Caan | 444 | 1457 | 0 | 0 | 0 | 57.3814 | -6.0296 | 1 | 4 | 04/06/2015 | GM4VPX/P |
GM/SI-095 | Scotland | GM | Scottish Islands | SI | Roineval | 439 | 1440 | 0 | 0 | 0 | 57.3323 | -6.2919 | 1 | 2 | 01/07/2013 | MM0SSD/P |
GM/SI-096 | Scotland | GM | Scottish Islands | SI | An Cruachan | 435 | 1428 | 0 | 0 | 0 | 57.2182 | -6.34 | 1 | 4 | 13/06/2011 | GM6WRW/P |
GM/SI-104 | Scotland | GM | Scottish Islands | SI | Beinn na Greine | 417 | 1367 | 0 | 0 | 0 | 57.3937 | -6.2308 | 1 | 5 | 23/09/2014 | MM1AWV/P |
GM/SI-105 | Scotland | GM | Scottish Islands | SI | Ben Tianavaig | 413 | 1355 | 0 | 0 | 0 | 57.3912 | -6.1439 | 1 | 7 | 26/06/2016 | MM3ZCB/P |
GM/SI-107 | Scotland | GM | Scottish Islands | SI | Beinn Bhac-ghlais | 408 | 1338 | 0 | 0 | 0 | 57.3704 | -6.611 | 1 | 1 | 03/09/2009 | GM4MD/P |
GM/SI-113 | Scotland | GM | Scottish Islands | SI | Mullach na Carn | 396 | 1298 | 0 | 0 | 0 | 57.2905 | -5.9748 | 1 | 1 | 19/07/2015 | MM0YCJ/P |
GM/SI-115 | Scotland | GM | Scottish Islands | SI | Sithean Bhealaich Chumhaing | 392 | 1287 | 0 | 0 | 0 | 57.4412 | -6.1529 | 1 | 5 | 26/06/2016 | MM3ZCB/P |
GM/SI-119 | Scotland | GM | Scottish Islands | SI | Biod Mor | 383 | 1257 | 0 | 0 | 0 | 57.2606 | -6.3616 | 1 | 1 | 27/08/2011 | GM4WSB/P |
GM/SI-128 | Scotland | GM | Scottish Islands | SI | Arnaval | 369 | 1210 | 0 | 0 | 0 | 57.2976 | -6.4091 | 1 | 3 | 30/06/2016 | MM3ZCB/P |
GM/SI-133 | Scotland | GM | Scottish Islands | SI | Ben Meabost | 346 | 1135 | 0 | 0 | 0 | 57.1668 | -6.0757 | 1 | 3 | 28/04/2018 | GM7PKT/P |
GM/SI-139 | Scotland | GM | Scottish Islands | SI | Beinn Chreagach | 328 | 1075 | 0 | 0 | 0 | 57.4895 | -6.5258 | 1 | 2 | 23/08/2011 | GM4WSB/P |
GM/SI-140 | Scotland | GM | Scottish Islands | SI | Beinn Bhreac | 327 | 1074 | 0 | 0 | 0 | 57.4847 | -6.5854 | 1 | 7 | 29/06/2016 | MM3ZCB/P |
GM/SI-144 | Scotland | GM | Scottish Islands | SI | Biod an Athair | 313 | 1028 | 0 | 0 | 0 | 57.495 | -6.7454 | 1 | 4 | 29/06/2016 | MM3ZCB/P |
GM/SI-150 | Scotland | GM | Scottish Islands | SI | Beinn nan Carn | 301 | 988 | 0 | 0 | 0 | 57.1917 | -5.9145 | 1 | 3 | 28/04/2018 | GM7PKT/P |
GM/SI-151 | Scotland | GM | Scottish Islands | SI | Sgorach Breac | 299 | 981 | 0 | 0 | 0 | 57.1495 | -5.8852 | 1 | 5 | 31/03/2018 | GM7PKT/P |
GM/SI-152 | Scotland | GM | Scottish Islands | SI | Cruachan Glen Vic Askill | 297 | 976 | 0 | 0 | 0 | 57.4282 | -6.4049 | 1 | 2 | 03/10/2013 | GM4MD/P |
GM/SI-155 | Scotland | GM | Scottish Islands | SI | Sgurr na h-Iolaire | 292 | 959 | 0 | 0 | 0 | 57.1101 | -5.9372 | 1 | 5 | 31/03/2018 | GM7PKT/P |
GM/SI-158 | Scotland | GM | Scottish Islands | SI | Meall a’Mhaoil | 284 | 932 | 0 | 0 | 0 | 57.3021 | -6.0641 | 1 | 6 | 30/06/2016 | MM3ZCB/P |
GM/SI-159 | Scotland | GM | Scottish Islands | SI | Ben Geary | 284 | 931 | 0 | 0 | 0 | 57.5599 | -6.5948 | 1 | 5 | 02/06/2015 | GM4VPX/P |
GM/SI-161 | Scotland | GM | Scottish Islands | SI | Sgurr nan Caorach | 281 | 921 | 0 | 0 | 0 | 57.0551 | -5.971 | 1 | 2 | 31/03/2018 | GM7PKT/P |
GM/SI-176 | Scotland | GM | Scottish Islands | SI | Beinn na h-Iolaire | 254 | 833 | 0 | 0 | 0 | 57.4792 | -6.007 | 1 | 3 | 24/03/2015 | MM0WML/P |
Except that’s Skye not Mull! Sorry discussing a Cuilin Ridge trip a work colleague did this lunch time!
GM/SI-003 | Scotland | GM | Scottish Islands | SI | Ben More | 966 | 3170 | 0 | 0 | 0 | 56.4251 | -6.0138 | 6 | 11 | 20/06/2017 | GM4VFL/P |
GM/SI-016 | Scotland | GM | Scottish Islands | SI | Dun da Ghaoithe | 766 | 2512 | 0 | 0 | 0 | 56.4603 | -5.7803 | 4 | 3 | 24/08/2014 | MM3WJZ/P |
GM/SI-017 | Scotland | GM | Scottish Islands | SI | Beinn Talaidh | 763 | 2502 | 0 | 0 | 0 | 56.4445 | -5.8551 | 4 | 2 | 12/05/2018 | GM7PKT/P |
GM/SI-019 | Scotland | GM | Scottish Islands | SI | Sgurr Dearg | 741 | 2430 | 0 | 0 | 0 | 56.4403 | -5.7897 | 4 | 2 | 21/04/2018 | GM7PKT/P |
GM/SI-029 | Scotland | GM | Scottish Islands | SI | Ben Buie | 717 | 2353 | 0 | 0 | 0 | 56.3754 | -5.8821 | 4 | 1 | 10/10/2004 | GM4COX |
GM/SI-031 | Scotland | GM | Scottish Islands | SI | Corra-bheinn | 704 | 2311 | 0 | 0 | 0 | 56.4195 | -5.9369 | 4 | 2 | 01/05/2008 | MM1BJP |
GM/SI-034 | Scotland | GM | Scottish Islands | SI | Beinn Fhada | 702 | 2303 | 0 | 0 | 0 | 56.442 | -5.9928 | 4 | 3 | 04/06/2012 | GM4WSB/P |
GM/SI-035 | Scotland | GM | Scottish Islands | SI | Creach Beinn | 698 | 2290 | 0 | 0 | 0 | 56.3817 | -5.8212 | 2 | 1 | 19/06/2017 | GM4VFL/P |
GM/SI-040 | Scotland | GM | Scottish Islands | SI | Cruach Choireadail | 618 | 2028 | 0 | 0 | 0 | 56.4053 | -5.9014 | 2 | 1 | 16/10/2005 | GM4COX |
GM/SI-043 | Scotland | GM | Scottish Islands | SI | Beinn a’Ghraig | 591 | 1939 | 0 | 0 | 0 | 56.4626 | -5.9934 | 2 | 3 | 01/06/2016 | GM4DKH/P |
GM/SI-055 | Scotland | GM | Scottish Islands | SI | Coirc Bheinn | 561 | 1841 | 0 | 0 | 0 | 56.4195 | -6.0764 | 2 | 3 | 30/08/2011 | GM4WSB/P |
GM/SI-061 | Scotland | GM | Scottish Islands | SI | Beinn na Sreine | 521 | 1710 | 0 | 0 | 0 | 56.3963 | -6.1242 | 2 | 3 | 30/08/2011 | GM4WSB/P |
GM/SI-067 | Scotland | GM | Scottish Islands | SI | Beinn na Croise | 503 | 1649 | 0 | 0 | 0 | 56.3551 | -5.9529 | 2 | 3 | 21/06/2016 | GM4WSB/P |
GM/SI-085 | Scotland | GM | Scottish Islands | SI | Beinn na Duatharach | 456 | 1495 | 0 | 0 | 0 | 56.4578 | -5.8905 | 1 | 2 | 20/05/2016 | GM4OIG/P |
GM/SI-091 | Scotland | GM | Scottish Islands | SI | Speinne Mor | 444 | 1458 | 0 | 0 | 0 | 56.5734 | -6.0735 | 1 | 3 | 18/05/2016 | GM4OIG/P |
GM/SI-101 | Scotland | GM | Scottish Islands | SI | Beinn na Drise | 424 | 1392 | 0 | 0 | 0 | 56.5084 | -6.1055 | 1 | 1 | 05/06/2012 | GM4WSB/P |
GM/SI-106 | Scotland | GM | Scottish Islands | SI | Beinn Bhuidhe | 413 | 1355 | 0 | 0 | 0 | 56.4894 | -5.9165 | 1 | 3 | 17/05/2016 | GM4OIG/P |
GM/SI-109 | Scotland | GM | Scottish Islands | SI | Druim Fada | 405 | 1329 | 0 | 0 | 0 | 56.3363 | -5.8085 | 1 | 3 | 21/06/2016 | GM4WSB/P |
GM/SI-123 | Scotland | GM | Scottish Islands | SI | Beinn Chreagach | 377 | 1236 | 0 | 0 | 0 | 56.3216 | -6.0174 | 1 | 5 | 19/06/2016 | GM4WSB/P |
GM/SI-124 | Scotland | GM | Scottish Islands | SI | Cruachan Min | 376 | 1232 | 0 | 0 | 0 | 56.3186 | -6.1336 | 1 | 3 | 20/06/2016 | GM4WSB/P |
GM/SI-135 | Scotland | GM | Scottish Islands | SI | Maol Ban | 338 | 1109 | 0 | 0 | 0 | 56.3497 | -5.7516 | 1 | 3 | 21/06/2016 | GM4WSB/P |
GM/SI-138 | Scotland | GM | Scottish Islands | SI | Creachan Mor | 331 | 1086 | 0 | 0 | 0 | 56.3025 | -6.0494 | 1 | 2 | 16/05/2016 | GM4MD/P |
GM/SI-145 | Scotland | GM | Scottish Islands | SI | Beinn Chreagach | 313 | 1026 | 0 | 0 | 0 | 56.4821 | -6.2197 | 1 | 1 | 07/06/2012 | GM4WSB/P |
GM/SI-153 | Scotland | GM | Scottish Islands | SI | 'S Airde Beinn | 295 | 968 | 0 | 0 | 0 | 56.6068 | -6.1227 | 1 | 5 | 02/08/2016 | MM/HB9BAB/P |
GM/SI-167 | Scotland | GM | Scottish Islands | SI | Tom nam Fitheach | 275 | 901 | 0 | 0 | 0 | 56.5583 | -6.1207 | 1 | 4 | 20/05/2016 | GM4OIG/P |
GM/SI-180 | Scotland | GM | Scottish Islands | SI | Carn Ban | 248 | 812 | 0 | 0 | 0 | 56.3973 | -5.6946 | 1 | 4 | 14/04/2018 | GM7PKT/P |
GM/SI-220 | Scotland | GM | Scottish Islands | SI | Gometra | 155 | 509 | 0 | 0 | 0 | 56.4905 | -6.2889 | 1 | 1 | 07/06/2012 | GM4WSB/P |
OK, that’s all brilliant. Thanks.
Activating all those will fill a couple of spare moments during a trip to Mull! Thank goodness there aren’t too many distilleries to distract
Which only means that you can concentrate your attention more on the ones that are there!
Thanks Andy, I needed Skye as I’ll be visiting there in September!
Ed.
Well it’s an excellent feature on the website and TBH I don’t think I have used it before. It was effortless to use and then you can download the summits in the enclosed polygon in various formats. I used the summits along a road route as well, another useful feature.
G4TGJ
Are you planning to activate some of the Mull summits? I’m always looking for a rare opportunity to chase some of my local summits
Yes. I’m there next week for half term with my family. Whether I get to go up many (or any) summits I don’t know. I’ll be on 2m FM and 20m CW/SSB. We are staying near Tobermory.
Distilleries on the Air… Points awarded based on the ppm phenols.
So I didn’t activate any summits. We didn’t have a drop of rain for the week and it was too hot for anyone to fancy going up a hill. I did activate a couple of beautiful beaches though. And I discovered the FT817 really needs a CW filter.
Pah! 28C here yesterday in France… that was a little warm for the last one. Much use of the A/C on getting back to car!
There are some who can do that filtering in their heads… I am not one of them. I prefer the 300Hz filter over the 500Hz. Keep your eyes peeled on the second hand ham websites and expect to pay £75 if you are lucky. I think they are £129 new if still available.
I shall try one of the Sotabeams filters.
