Anyone know where I can find the information on getting the UK version of the FT-857D to work on 60m ?
Stewart G0LGS
Stewart G0LGS
In reply to G0LGS:
Doesn’t Google work? I did a quick search and many results came up. Is there something about a UK 857 that makes the mods unsuitable?
Andy,
My google search came back with lots of stuff, but having looked at several I didn’t find one that gave me the answers I am looking for - Lots of references to USA models and memory channels that don’t seem to exist in this one.
The link on RigPix to a PDF of mods doesn’t seem to make it clear which Jumpers should be open and which ones closed.
I was hoping someone that has done the change would have a record of the information that they used.
Stewart G0LGS
In reply to G0LGS:
It will depend on the age of your 857D. Early ones just needed a bit of software called Wide-Bander and a programming cable. Later ones needed a surface mount diode removing. I seem to remember there was one diode you remove so you can use the Wide-Bander software and another that if you remove it the whole thing becomes wide-banded permanently. The options with Wide-Bander software are EU, USA and fully wide banded. USA gave you the American 5mHz allocation only and messed up the repeater shifts. Most people went for the fully wide-banded option as it also enabled the extra 100kHz we got on forty metres.
Steve GW7AAV
In reply to GW7AAV:
If it is a D model as you said, then almost certainly it will need the hardware mod. eMail me direct off list and I will send you the data.
73 de Peter G0FIM / AA3JN
In reply to G0FIM:
Not quite true. All none D models and most D models over about two or three years old only require the software mod. I have two of them and have programmed/unlocked half a dozen others (all D models), only the last one I bought (10/9/20008) needed the hardware mod. Another amateur I know bought his a couple of months earlier and it did not require the hardware mod.
Pretty much the same applies to the FT-817. I have one of these too and have programmed/unlocked another four. They locked them down because some country or other made a fuss. I can’t remember which country.
In reply to GW7AAV:
Uncle Sam.
M0FMF
