In reply to 2E0YYY:
Don’t drop it in the first place
We can hopefully have a meet tomorrow and I will try and have a little look for you.
Now, where did I put my hammer and mig welder?
In reply to 2E0YYY:
Mike
Remove rubber cover from knob,you should find small hole in knob, a 1.5mm allen key will be needed to release grub skrew at bottom.
TAKE CARE
Bob G6ODU
In reply to 2E0YYY:
look for you.
Just knew I could rely on you, for a sensible suggestion. OK, I’ll pop over tomorrow.
In reply to 2E0YYY:
Mike
TAKE CARE
Bob G6ODU
Thanks a million Bob …and thanks for the QSO from Shining Tor, today.
I was actually replacing the same part on my 857 as we were talking yesterday. It fell off on Pendle Hill the other Sunday. I just used a small cross point screwdriver as I couldn`t be bothered to look for an allen key.
allen key.
I picked up a set of Allen keys from the Pound Shop this morning. My T6 “Torx bit” tapered down from the top and hence too fat to fit all the way down into the small hole in the knob. I really don’t understand the love affair electrical manufactures have with Torx screws. It would appear the average mobile phone is full of them…
The reason they are favoured is primarily because the automated screw fitting machine can easily hold a Torx screw in its bit. This is not at all easy with cap Allen or other screws.
T6 is a particular favourite of electronics companies. I’ve got a short reach T6 driver with a thin shaft and it’s so useful. The T6 bit for my electric screwdriver is almost useless for the reasons you give, tapering to too fat to fit in the hole.
I had the same problem, but kind of semi-justified in the loosest terms the purchase of a mini lathe and tooling to turn down the original “fat” bit into a more usable slim-fast inspired item.
For everything else, there’s mastercard…
(In fairness, it has paid for itself many times over already)
