I created another Webapp that helps you finding potential activations that would “complete” the summit. I.e. it compares your chaser and activator logs, then shows summits that you chased but not yet activated. The results can be filtered by association:
The app shows only candidates for activation, as you only can plan these by yourself. If you like to be informed when a summit is on the air that you need for completion, I can highly recommend the app ‘Hamalert’ by Manuel, HB9DQM (HamAlert).
sri, it seems the weekly automated update of the callsigns failed because the sotadatabase was down at this moment. I restarted the update manually, now it works again.
Use the same callsign you have in the Sota DB (usually without /p).
