Elecraft T1 pcb size?
Hello all,
Been browsing around various websites trying to find measurements of the T1 pcb.
The FAQ’s states “about 2 by 3 inches”.
Anyone on the reflector who has an T1 and is willing to open it to take some measurments?
The reason is that I’m trying to find out if I could possibly fit it inside my MTR4B.
//Tommy, SA2CLC
Hi Tommy
70mm x 57mm x 18mm
The LEDs, buttons and BNC connectors not included.
HTH
Adrian
G4AZS
Tommy,
My (…) Elecraft T1 PCB size measures 71 x 57.5 mm (required free height min. 18 mm).
The distance between the 4 mounting posts (center-center) is 71 x 57,5 mm.
73 gl, Heinz
Hi Tommy,
On putting it back together, I notice that the 3.5mm socket on the side of the PCB also protrudes a few mm, as can be seen in the photo top left…
Thank you guys, looks like it would fit the bill quite well, the inside of the 4B box measures 101mm by 73mm. Only issue would be the minimum height but it should work. Is the “control board” the highest point, and can it be removed and relocated by using wires instead of pin headers?
I read too fast, buttons and leds not included :slight_smile:
18mm would leave 1mm gap… Might be a smidge to tight…
