Hi all,
since August I will be working and living in Dublin for a few years. Of course I am bringing my equipment with me and looking forward the summits in Wicklow Mts. and other areas. For the start I’ll use EI/OK1HAG/P callsign but after few months I should apply for an EI callsign. After reading the resources at Comreg and IRTS websites, I have some questions:
- is it still true that EI callsigns are assigned sequentially without an option to choose your preferred number+suffix?
- in case I can choose my callsign, is there a resource to check which callsigns are available?
- if I present a copy of 12 WPM CW exam certificate from OK, will I get a Class 1 license?
Thanks for replies and CU from EI/IE summits
Marek OK1HAG
