A few times today I have had the message below from the Spots side of Sotawatch. Don’t know if its anything to worry about. Anyone else seen it?
Q GW3BV
“Sorry, SOTAwatch2 had a problem with the old SOTAwatch database which unfortunately it still is using at the moment.
(Error: Lost connection to MySQL server during query). Please click here to return to the home page.”
Yes, the error message was meant to convey: Don’t panic but we may need to put up with this until I can ditch the old SOTAwatch database. It’s the same thing that causes the old system to drop out as well at times.
I am still relying on the old system for spots, alerts and users. I have moved across summits, summit info, etc. and will move across users soon.
I have slightly improved matters by executing a web forward to the home page when the database connection breaks.
I think in most cases this will actually revert back to a cached version of the homepage which will then try and refresh again after 30 seconds. So hopefully any problems will pass virtually unnoticed.
At the moment I now seem to be getting a posting from WEBMON every minute now
whereas it was not happening before earlier on this morning even allowing for the postings.
