In reply to G8ADD:
In reply to GW0DSP:
Surely the repeaters need restricted range or the qrm would be
terrible and the numbers of hams able to use one at any time would be
limited.
Take a listen to GB3MP or GB3VT or GB3MN sometime, they have terrific coverage over great distances.
The emergency services are in the same position, its a matter
of service area and user numbers.
Surely they opted for rock solid reliability.
Vertical polarisation for mobile
operation was chosen for two very good reasons.
That’s news to me, all bands/modes are used mobile. Maybe you refer to the repeater useage.
secondly the mobile antenna is more easily
set up:
Hear hear, especially on a summit in winter wx
horizontal polarisation over a metallic ground plane needs
precise spacing to hold the radiation pattern close to the horizon.
Add to this the greater ease of accommodating an antenna with gain.
Stacked halos or turnstiles would be quite unwieldy atop a mini!
I don’t see the relevence. This debate was purely about you not hearing a sota activator on a summit, I doubt you will see many minis on Snowdonian summits.
Incidentally, there used to be a horizontal FM group which
demonstrated that FM was only a little inferior to SSB if a horizontal
antenna was used.
Just as horizontal ssb is inferior to horizontal CW.
That group faded away but the idea is being revived
by another band of enthusiasts, I have worked some of them over quite
good distances!
I use horizontal FM myself from Hope Mtn because it prevents the desensing from the commercial stuff, just as horizontal ssb does.
In fact I so rarely use FM and vertical polarisation that I would have
to change antennas manually (and search for the right coax!) but a
crossed yagi would be great if they were not so infernally visible and
likely to arouse the attention of the planners! I keep my head down
and hope!
That is a choice only you can make, it’s not the problem or fault of the chap on the summit using vertical ssb.
I take it you suffer from strict planning regs by the sound of it Brian, that must be a real blessed nuisance.
73 Mike
