Hi!
I’ve been trying to upload my new log but something went wrong. I’m pretty sure the format is OK. After that I tried to upload again my last week log that I already uploaded without error. Wont work.
The 1st line of my log is V2,HA5LV/P,HA/ND-017,29/04/15,10:27,7MHz,CW,HB9BHW/P,HB/ZH-004
Thank you! It works!
Anyway I have wrote my own utility to make my life simpler to generate a csv from the ADIF.
I uploaded at least 30 logs without that comma at the end. It was not needed before, something must be changed.
Thanks again for the replay.
73 Viktor
Indeed it was me The error reporting on CSV upload should be better now. Apart from when it does not work, when the reporting is worse!
I’ll have a fix uploaded soon, but the quick fix is to add a comma to the end of the lines without a comment. There is probably something broken in the Chaser upload as well.
If you select “View Results>Facts and Figures” you can find the code version running, now it is Version : 1.4.5598.35786 Created (UTC): 30-Apr-15 19:52:53 and this will change when I upload a fix.
