Different Error
Could not allocate space for object âdbo.ActivatorLogsâ.âPK_ActivatorLogâ in database âsotadata_dbâ because the âPRIMARYâ filegroup is full. Create disk space by deleting unneeded files, dropping objects in the filegroup, adding additional files to the filegroup, or setting autogrowth on for existing files in the filegroup.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Data.SqlClient.SqlException: Could not allocate space for object âdbo.ActivatorLogsâ.âPK_ActivatorLogâ in database âsotadata_dbâ because the âPRIMARYâ filegroup is full. Create disk space by deleting unneeded files, dropping objects in the filegroup, adding additional files to the filegroup, or setting autogrowth on for existing files in the filegroup.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[SqlException (0x80131904): Could not allocate space for object 'dbo.ActivatorLogs'.'PK_ActivatorLog' in database 'sotadata_db' because the 'PRIMARY' filegroup is full. Create disk space by deleting unneeded files, dropping objects in the filegroup, adding additional files to the filegroup, or setting autogrowth on for existing files in the filegroup.] System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action
1 wrapCloseInAction) +3305804
System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) +736
System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) +4061
System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async, Int32 timeout, Boolean asyncWrite) +1293
System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) +421
System.Data.SqlClient.SqlCommand.ExecuteNonQuery() +380
SOTA.AddActivatorEntry.AddEntry(SqlConnection dbConnection, Int32 userID, String ownCallsign, Int32 summitID, DateTime activationDate, DataTable QSOTable, String& QSODetails) in c:\SOTA\SOTADATABASE_Net45\AddActivatorEntry.cs:302
[ApplicationException: Database Error Adding Activator Entry]
SOTA.AddActivatorEntry.AddEntry(SqlConnection dbConnection, Int32 userID, String ownCallsign, Int32 summitID, DateTime activationDate, DataTable QSOTable, String& QSODetails) in c:\SOTA\SOTADATABASE_Net45\AddActivatorEntry.cs:319
SOTA.ActivatorCSV3.UpdateDatabase(SqlConnection dbConnection, StreamReader sr) in c:\SOTA\SOTADATABASE_Net45\ActivatorCSV3.aspx.cs:299
SOTA.ActivatorCSV3.Button1_Click(Object sender, EventArgs e) in c:\SOTA\SOTADATABASE_Net45\ActivatorCSV3.aspx.cs:102
[ApplicationException: Error in ActivatorCSV3.UpdateDatabase]
SOTA.ActivatorCSV3.Button1_Click(Object sender, EventArgs e) in c:\SOTA\SOTADATABASE_Net45\ActivatorCSV3.aspx.cs:123
System.Web.UI.WebControls.Button.OnClick(EventArgs e) +11758496
System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) +150
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +5028`
