I have created this thread to save all the recent error reports.
Same here!
The activator file could be uploaded without problems, only the chaser file goes into hick-up.
73 Heinz
For me itās the other way round. Uploaded the chaser log but the activator log got kicked backā¦
73, Sylvia OE5YYN
Entered my activator and S2S (chaser) contacts manually (i.e. not a CSV file) - all went fine.
I just tried entering my log manually for todayās activation and it failed on the last step after you click āI agreeā.
Same problem here.
Error says the server has run out of file space. Thatās why the csv are not found (because they can not be uploaded). I guess
73 Joe
Hi
Excellent event! But I cannot uploaded the chaser and the activator log.
73 de HB9BIN, JĆ¼rg
I cannot manually enter chaser or activator logsā¦
Iāve been back about 30mins from the GM Microwave Roundtable and have been investigating what was happening. It appeared there was no disk space on the server and my control panel file manager was not responding. I submitted a ticket reporting the error and popped to the loo for about a minute. On my return the file manager is responding and says we have 4GB of file space at least.
It looks like something was broken on the server and it has been fixed. Whether it was a result of my ticket weāll never know as that would be a fast response. Itās 2315Z now. If you want to try a log upload, wait till gone 2330Z just to let the load drop on the servers as probably other customers who share the service may be hitting the server hard after it has come up. Iāll see if itās working in the morning or if there are more issues to resolve.
Still not working. 2343z
Ahoi
Pom
0139 NOT WORKING
Pete
WA7JTM
Yes, still getting same error when uploading chaser/s2s csv
Barry n1EU
It wonāt take my manually typed activator log - same message.
KX0R
The database did accept a large bunch of single, manually-typed chaser logs with no problems. It also accepted a single S2S entry.
It still canāt accept my activator log with 40 entries, although it has saved it OK in the initial form, and itās still sitting there. Iām wondering if Iāll have to re-type the whole thing before this is overā¦
KX0R
04/11/2018 06:52 UTC: No difference if āimportā or āsubmitā.
Still no disk space.
Blockquote An error has occured whilst saving the Activation Details :
System.ApplicationException: Database Error Adding Activator Entry ā> System.Data.SqlClient.SqlException: Could not allocate space for object ādbo.ActivatorLogsā.āPK_ActivatorLogā in database āsotadata_dbā because the āPRIMARYā filegroup is full. Create disk space by deleting unneeded files, dropping objects in the filegroup, adding additional files to the filegroup, or setting autogrowth on for existing files in the filegroup. at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async, Int32 timeout, Boolean asyncWrite) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource
1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at SOTA.AddActivatorEntry.AddEntry(SqlConnection dbConnection, Int32 userID, String ownCallsign, Int32 summitID, DateTime activationDate, DataTable QSOTable, String& QSODetails) in c:\SOTA\SOTADATABASE_Net45\AddActivatorEntry.cs:line 302 ā End of inner exception stack trace ā at SOTA.AddActivatorEntry.AddEntry(SqlConnection dbConnection, Int32 userID, String ownCallsign, Int32 summitID, DateTime activationDate, DataTable QSOTable, String& QSODetails) in c:\SOTA\SOTADATABASE_Net45\AddActivatorEntry.cs:line 319 at SOTA.AddActivation3.Button1_Click(Object sender, EventArgs e) in c:\SOTA\SOTADATABASE_Net45\AddActivation3.aspx.cs:line 83
I could just upload my chaser/S2S file, but the activator file had the same problem. Also entering QSOās manually doesnāt help, error after clicking āI agreeā.
Need to go back again Iād say.
