Chaser database error
I’m trying to log a chaser contact in the database and I’m getting an error message from the server as follows:
Validation of viewstate MAC failed. If this application is hosted by a Web Farm or cluster, ensure that configuration specifies the same validationKey and validation algorithm. AutoGenerate cannot be used in a cluster.
Is this something I’m doing wrong or a problem with the database?
The entry I’m try to log is:
Assoc: OK
Region: PL
Summit: 003
16/10/10
14:35
g8tmv/p
ok/dl3sba/p
7MHz
SSB
Is anyone else having problems logging chaser QSOs (I can log activator QSOs ok).
Colin G8TMV
In reply to G8TMV:
I’ve had this a couple of times, Colin, I don’t know what causes it, but if I log out and then back in it clears up.
In reply to G8ADD:
Thanks Brian, that fixed it.
btw, nice to work you from G/SE-013 yesterday
Colin
