Calling tom
why is it everytime tom is spotted on a ssb vhf/uhf frequency he always moves away. Is tom doing the chasing or staying put. ??? I have seen the spots a few times and then found tom calling further away from qro
In reply to M0SGB:
qro
Can someone translate this as it doesn’t make sense to me.
Andy looks like my mobile phone is playing up again only half message. And you know that i always sign with my callsign. Steve m0sgb
In reply to M0SGB:
That explains things.
And i have forgot what i wrote steve m0sgb.
In reply to M0SGB:
Most of the contest stations spend part of their time calling on their frequency and part of the time in hunt and pounce mode, often using the twin VFOs. A common trick is to call a few times, change VFO, tune a few 10s of kilohertz, stop on an unworked station that is working someone (or if you don’t find anyone stop after a short time), go back to VFOa and call a few more times (thus holding the channel) switch back to VFOb and if the other station is CQing again, call him.
I don’t know that Tom does that, but it is quite possible. It is an efficient method!
In reply to G8ADD:
Perhaps Tom calls “tuning high to low” after each CQ :slight_smile:
High to low, low to high and both ends to the middle. I still have the crystals HI.
Regards, Mike G4BLH
In reply to G4BLH:
Golly yes, the old “Geographical” band plan, I still have my old crystals as a memento - huge things with pencil marks on to shift me away from other locals!
Thanks for the memories…that would be a good title for a song! :wink:
I think Steve’s initial question was tongue-in-cheek Brian. Steve is an experienced VHF contester and has at least one Backpackers triumph to his name. He knows how contest operation goes!
Tom M1EYP
In reply to M1EYP:
I thought it probably was, Tom, but I went ahead anyway as it might have been useful for non-contesters!
In reply to G8ADD:
What’s this “old” stuff Brian… that band plan is still in use up here in Edinburgh!
Sorry, Andy, will “old-established” do?
In reply to M1EYP:
Hi Tom, Andy and Brian. Tom it is was not tongue in cheek, I have seen the spots for you when in contest, but never found you on that frequency, Yes i know from past contests what its like and how to do it. I have been spotted on a frequency and stayed to work as many contesters/chasers as possible, Only when the qso’s have dried up, have i gone tuning around to find other sqaures, I did hear a station from io92 here in Ramsbottom but very weak, sadly never got him, but did work a few others from the mobile.Any way hope you had a good time. phone’s rining and tea ready so must dash, (my excuse)
Steve m0sgb
“Only when the qso’s have dried up, have i gone tuning around to find other sqaures…”.
Indeed.
Tom M1EYP
