Call sign upgrades
In reply to 2E0HJD:
Thanks for this Mike.
I think I have now fixed this. Could you have a check and let me know?
Thanks
Jon
In reply to 2E0HJD:
Hi Mick,
This will probably be because you have chased them in the last 2 or 3 days. Is this correct?
The reason for this is that the summit list operates on an imported set of chaser logs whereas the summit page connects directly to the SOTA database at the time of page generation. There is reason behind this apparent inconsistency - mainly to do with performance and other upcoming statistics which I am going to make available shortly in SOTAwatch.
At the moment I am manually running an import script every now and then (when I remember) but I will set up a scheduled nightly import shortly.
I have just run an import, so hopefully the two will match at the moment. Can you confirm?
Thanks
Jon
