Does any body else have a strange beam heading for NP032. I have 178 deg from here and it should be around 350
73 Graham G4JZF
73 Graham G4JZF
In reply to G4JZF:
The lat. and long. haven’t been entered Graham so only those due south of NP-032 will have correct bearing
Roger G4OWG
In reply to G4OWG:
The Birmingham conurbation is close to due south of NP-032, Roger!
In reply to G8ADD:
Whoops mean due North
Roger
In reply to G8ADD:
I think Graham means the beam heading in Sotawatch is dodgy. I have 178 in Sotawatch but Clive is exactly where he should be, approx 45 degrees from my QTH.
Mike GW0DSP
In reply to G8ADD:
Many thanks both for info. Managed to pick Clive up okay for unique !!.
Still want NW-063 for last G/GW summit.
73 Graham g4JZF
In reply to G4JZF:
I’m not quite sure why SOTAwatch doesn’t have the lat/long entered for G/NP-032. Of course it is a late addition to the list, but it has been in the lat/long lists I supply to GM4ZFZ for some time, so it ought to be there. I think only Jon can answer this one.
