Hi All
I am the proud owner of a shiny new-ish Alinco DJ-G7 and have bit of a problem.
I want to enter the local repeaters into the beast for saftey whilst climbing. The problem is the auto repeater function. When enabled, 2m and 23cm shift work correctly, but 70cm does not appear to have any kind of shift enabled. The radio is the “E” version.
I have the radio set in vfo mode, no memories programmed (as I am still waiting for the cable to be delivered)
Has anybody seen this problem and if so how do I get around it please?
The pliable mallard that comes with the G7 is almost useless. Best use for it is a dust cover for the SMA on the set!
I have too many handhelds to remember how they work anymore. I can turn them on, tune a VFO for simplex QSOs and possibly defeat the squelch. We wont go into how mind numbingly complex the Icom IC80 is to use.
I have enabled auto rpt, it adds the shift to 2m and 23cm but not
70cm…
The manual says that on the E version the auto shift on 70 cms is not available I wonder if that’s because there are two alternatives in the UK - 1.6Mhz and 7.6Mhz. The T version has a 5 Mhz shift??
Auto repeater shift is goofy for European use. So dial up the RX in VFO mode then press FUNC and quickly press MAIN to cycle through + shift, - shift and no shift. You can use the main top rotary dial to alter the shift amount. This way you can program any split you like. You can save the rx/tx pair in a memory and can have different splits for each memory saved.
In answer to your question - Yes it does!! Very strange when you are talking into the thing on 2m and you hear your 70cms local repater coming through the speaker into your gob HI!!!
Have used my extensively on 23cm for SOTA with my 11 ele beam and out and about round my town with an RH770 Antenna by Sharcom - Works really well, battery life is excellent and the ergonomics are good!
I tried to make one myself, however for the price of the 11 ele, it was not worth it!
However i would like to get my hands on some of the Tonna plastic moulded driven elements for 23cm!! Would be very good to use this in conjuction with a bit of Plastic and home brew elements.
Or alternatively have a go at the Bow Tie Antenna!
Antenna, Fully working, tested and deliversd 24 pounds! Aluminium Box section for boom, Thick Ally rod for elements! Weatherproof box for the driven element, Ntype on the feedpoint ( You and I sing from the same Hymn book on N type and PLs!) Enough said really, Having said that knowing your usual replies Andy, you will have something to say!
However I would like to see your design for the Bow tie Antenna, very simple and extremely lightweight I presume!
I’ve got a link to the design I copied on the PC at home not this one. I’ll post it later. Brian G4ZRP made one as per the measurements using no special tools at all. The match appears very good, he fed a dummy load through a Bird43 from his Delta 100 and checked the forward and reverse powers measured on 1297.5MHz with 10W. Forward showed 10W and reverse showed zilch. Then he swapped in the antenna and the results were the same. Probably 1.1:1 or better then.
His works well… stations in the LD with him on The Wirral that are inaudible on 23cms using the DJ-G7 and rubber duck are 55 on the double quad. That’s inside the loft shack as well!
