Activation Report : 6 NP's
Six NP summits
Our last 5 summit round of activations in the Lake District in October culminated in a Mountain Goat activation for Paul on the summit of Helvellyn. This could have been the signal for a well-earned rest, but as is usually the case, the discussion on our return journey turned to which summits were we going to activate next. We mentally ran through the LD and NP summits that we still had to activate and we both came to the conclusion that it would be a nice idea to polish off the NP’s by the end of the year. I had already prepared draft itineraries for a 4 summit round over 2 days based at the Scotch Corner (Skeeby) Travelodge. Paul came up with the brilliant idea of adding two of the remaining summits to this with two night’s stay at the Travelodge if we could get rooms at the £19 bargain rate. A few days after our return, Paul emailed me to say that he had booked two rooms for the nights of 14th and 15th November. The sortie was on – all I had to do was review and make one or two timing adjustments to the itineraries, prepare the kit and wait.
Day 1, Sunday 14th November, required a reasonably early start – 03:50 in fact. It was dry, calm and 6C when I left Northampton and it was about the same temperature when we departed Stourbridge at 05:30, though rather more damp. A good run up the M6 provided us with an early arrival at the parking spot for Nine Standards Rigg G/NP-018 on the B6270. It was 08:12 when we parked the car and we were already 18 minutes ahead of schedule – better that than being late. The temperature at the parking spot was just 1C and the forecast was for showers – delightful! We had driven through some heavy rain while on the M6 near Preston, but as it turned out, the only water to cause us any bother during the day had already fallen and was lying on the ground. In my winterised schedule I had allowed a lazy one hour and twenty minutes to get to the summit and we needed almost all of this, as the ground was extremely boggy. Seemingly innocent patches of grass and reed turned out to be vegetation that hid water, up to around half a metre deep in places. It wasn’t that long before the wet assault on our gaiters meant that we experienced a cold wet feeling as brown brackish water found its way over the tops of our boots. Once breached, the temperature inside our boots plummeted and with my poor circulation, I arrived at the trig already devoid of feeling in my feet and Paul was not that much more comfortable.
The light breeze at the parking spot at 510m had turned itself to a sharp cold wind at the 662m summit which was quite aggressive in the near freezing temperature. Visibility had also gone down to little more than 20 metres and the summit area was awash in several centimetres of water. Paul decided that he could utilise the trig to support his pole and this provided some shelter from the weather. I wandered off a short distance and found a suitable position behind a ruined stone wall which also turned out to be useful for supporting my pole. It took me 20 minutes to get set up and I was ready to go by 10:08. I checked the beacons and moved to 144.333MHz to call CQ – no response. Well, we were early, having alerted for 10:30. I called several times, but no one came back, so I slipped my headphones off to check whether Paul was in action on 60m. I knew his appearance would start the regulars looking for me on 2m. By this time he was making a steady run of contacts, so I returned to the rig and checked it over – no power out on transmit – arghh! The voltmeter on the 857 showed that the 12AH SLAB I was using was collapsing as soon as I pressed the PTT. I had only one option – 2m FM on the C710 handheld. I didn’t know whether it would be successful, so I self-spotted advising that I would be using 145.400MHz and Paul M6PEW soon found me and confirmed my presence with another spot. It wasn’t easy going with just 1 watt, but a short run of contacts with John G0TDM, David G6LKB and Marjorie M3ULV qualified the summit for me and I managed another contact by calling when a QSO finished on 145.475MHz. Several more calls solicited no response, so I decided to call it a day and pack up. As if failure of the SLAB was not enough, the pole telescoped just as I stopped calling and this split the bottom cap. Fortunately I had all the parts for an on-site repair, so I set about this task as Paul finished off his activation. I noted the temperature indicated on my thermometer had risen to a balmy 2C.
Paul found 60m in fair condition and was hopeful of a large number of contacts as it was a Sunday. First up was the ever-vigilant John G0TDM who kindly posted a spot for Paul. Contacts came at a steady pace with no more than a couple calling at once, but it was all done and dusted within half an hour with16 contacts in the log. Where were the weekend cavalry? A brief look at 80m showed it to be extremely noisy, so seeing that I had already dropped my mast and was in the process of packing away, Paul too decided that he needed to get moving. I did wonder whether I would ever feel my feet again, but the circulation slowly started to return once we started our descent. The bad conditions on the ground prevented us from making a rapid descent and it took us just over the hour to get back to the car by 12:10, including of course the mandatory inspection of the limestone pavement that the tracks runs through – a really good example.
After sorting out ourselves for the next summit, we discussed the merits of changing our socks. For some strange reason, neither of us had brought a spare pair of boots, so we decided that on balance it would be better to just leave our footwear as it was, wet socks and all. The itinerary allowed a rather generous 20 minutes for lunch which we shortened to 13 minutes and we were away from the parking spot by 12:28. It was 21 mile drive along the B6270 and minor roads to reach the parking spot for our next summit, Hoove G/NP-024.
We parked at NZ018067 near the County Durham / Teesdale sign at 13:12 to find the bitterly cold wind was still with us. At least we could see where we were headed, but progress over the ground was relatively slow and it took a 40 minute yomp across heather and bog before we reached the trig at 14:00. I had generously allowed an hour for the ascent knowing the reputation of this route. Fortunately the man-made drainage ditches running in straight lines across the hillside seemed to be working and apart from avoiding innumerable mantraps and sink holes, it was an easier ascent than I had imagined. I was pleased to find the trig top open and clear so that I could easily deploy my pole, but I had to take care as a pond about half a metre deep had formed on three sides of the trig. Paul found shelter and a suitable operating position in a depression close to the summit, which was fortunately reasonably dry. I noted that the temperature was still a cool 2C and dropping slowly – well, at least we had no rain.
Paul was first to make a contact on this summit, with John G0TDM waiting on 60m for him despite the fact that we were 45 minutes early. Again the run was again steady and 13 contacts were made on 60m in just over half and hour. Paul recorded his first S2S of the expedition on this summit working Kjell LA1KHA/P on Holtankollen LA/TM-049. After working Keith G7WCM at 14:49 the frequency went quiet, so Paul took a look at 80m. The band was still noisy and the skip seemed to be long with lots of European traffic, so after a while calling without success, he decided to call it a day.
My first contact on 2m SSB at 14:20 was with Roger G0TRB. Signals were not particularly strong and it took the full 50 watts from the FT-857 to get the report across to Mike G4BLH who followed on. A mix of power levels was then used to get the best out of my battery pack, knowing that, with the expiry of the SLAB, I would need some reserve for the final summit of the expedition. In all I worked just 7 stations on 2m and one on 70cms – Phil G4OBK, who was stronger on 70cms than on 2m. After a few more calls on both bands, I took the opportunity to take some photographs. Paul told me that Don G0RQL was looking for me, so I went back to my kit, turned the beam down to the south-west and gave it the full 50 watts and managed to make the QSO. After a few more calls on 2m, I went QRT at 15:08. The trek back to the car was only marginally quicker than the ascent, but then there is only 39m of ascent for this summit, the challenge being entirely down to the ground conditions.
The temperature when we reached the car had dropped to zero. We were both pleased to finally put on dry socks and footwear before leaving for our overnight accommodation. A short drive up to the A66 and across to Scotch Corner had us checking in at the Travelodge at 16:47 and after deploying our boots and washing the brackish water out of our socks, we convened in Paul’s room for scoff, which was excellent as usual. After this a hot shower and a spot of TV watching preceded a decent night’s sleep for us both.
For once our rooms were more or less opposite, so it was an easy thing to meet up the following morning at 05:45 before going out to the car. The receptionist told us it was chilly – well minus 2C chilly and ice to remove from the car windscreen, but nothing to bother us. It was a reasonably pleasant drive back down the winding B6270 to near Keld where we parked up in a rough lay-by at NY892006. The route up Kisdon G/NP-026 is easy to follow and initially goes along a track – here we met a local farmer walking his dog. Just past a farm cottage set back on the left, we cut left across to the OA land. Then it was a short stiff climb up to a gate and around the side of the hill, veering right past a corner in a stone wall and then over a lower section of the wall to the summit. It was initially fairly steep on the track, but this was just what we needed to get us going on this crisp sunny morning. It was minus 2C at the summit with sun and minimal cloud – more importantly, it was absolutely still and this made for extremely pleasant operating conditions. I went for the highest spot and Paul took advantage of the luxurious seating facilities offered by the beehive cairn nearby.
We were alerted for 08:30 and were just a little early when we got on air. My first call went unanswered, but the next call brought in Geoff G6MZX, shortly followed by Bob G6ODU. I was spotted by Bob and also by David G6LKB. John MW1FGQ called in for QSO number 3 and we tried on 70cms, but nothing was copied either way on that band. Back on 2m at 08:30, the run then started. After working David G6LKB, I raised the power to 40 watts to work Laurie G6XLL and David G2BOF and left it there until the frequency went quiet at 08:45. I had 11 in the bag with Don G0RQL providing the best DX. After a few unanswered calls on 70cms and a wander around to take some photographs and get my circulation going, I put a call out to the north on the 2m SSB calling frequency and Jack GM4MOX in Kirkcaldy came straight back. So much for Kisdon being an RF black hole!
Paul’s first contact on 60m was with Roger G4OWG who also spotted him. Conditions were again reasonable on the band producing a very pleasant run of 17 contacts from Don G0RQL in Devon up to Ken GM0AXY in Edinburgh to near match the geographical spread of my contacts. A little after 09:00, Paul moved to 80m where he found much quieter conditions than the previous day and worked Frank G3RMD followed by G8ADD, G3RDQ and G0RQL to qualify the summit on that band. By the time we had finished, the sun was warming the summit nicely and the frost was starting to disappear. All looked good for our next summit.
We started our descent at 09:38 and were back at the car by 10:06. I had allowed time for a snack at this point, but we decided to take a drink and “bun” up the next summit instead, so got on the road back to Gunnerside and our parking spot at SD941983. The track leading to the summit of Rogan’s Seat G/NP-014 was more or less opposite our parking spot on a wide grass verge – a 6.7km walk on a private vehicle track.
The walk to Rogan’s Seat was very pleasant indeed with some excellent views, a small waterfall, a slippery patch where the track was wet and in shadow, designer grouse butts and plenty to look at along almost its entire length. My winterised schedule allowed 2 hours and 40 minutes – we managed it in 1 hour and 48 minutes and that was taking it reasonably easy. The worst part was traversing from the track to the summit, which sits on a hag bank and is marked by a small pile of stones. We had several options – sit in the wet at the summit, try out an old grouse butt nearby or use the fence nearby for an easy set up. We decided on the latter. To get out of the cold wind, I used my plastic tarpaulin tie wrapped to the fence and once sat on my insulating pad, it was very pleasant indeed. Paul set up a short way down the fence. The first thing for both of us was lunch, eaten as we started to set up our stations – it’s amazing how good relatively simple food tastes when consumed out on a summit.
I was ready to go by 12:45, but we were a full hour earlier than we had alerted for and it was lunch time. Several CQs went unanswered and I did not have mobile phone coverage to self-spot, so I had to be patient and let the channelised magic of 60m do its work. First up for Paul at 12:52 was his namesake G0HNW – a renowned 60m operator, but not a SOTA chaser. Fortunately Brian G8ADD was second on parade and the spot was soon in place. Don G0RQL eventually kick-started my activation. Paul had a very steady run for around 50 minutes and made 21 contacts on 60m around G, GI, EI and GM. At 13:40 he moved to 80m and starting with Frank G3RMD who kindly provided a spot, another six contacts were made. Paul was then given the heads-up that Pavel OK1MCS was activating Ebene DM/BM-092 on 40m SSB, so a quick QSY was taken to pick up the S2S. Returning to 80m, Paul then worked Nick M6NJB and Pete M0COP provided Paul with his 30th contact on the summit.
As already noted, Don G0RQL was my first contact at 13:07 and the one to spot me. Just a short run ensued to put 6 in the log on 2m SSB before the frequency went quiet. I moved to 70cms and decided to start with CW knowing that Frank G3RMD would be looking for me. My first call was actually answered by Reg G3WPF and we had a pleasant chat on the key for a few minutes. Frank followed on to give me a second contact on the band. I tried a few more calls both on CW and SSB without result before moving back to 2m to pick up another run of 4 ending with David G8EQD.
We started to dismantle our stations at 14:18 and made our descent at 14:32. It took us a steady 1 hour and 25 minutes to get back to the car, an indication of how well we had progressed on our ascent. We changed our footwear for the drive back to the Travelodge and arrived there at 16:57. We decided to pay Richmond a visit during the evening and ended up in Wetherspoons for a bite to eat and some ale which made a pleasant change. Commencement of the pub quiz at 20:30 was the cue for our exit. The ale wasn’t particularly good anyway.
The itinerary on Tuesday 16th November required an earlier start than the previous day. The temperature was around minus 2C again, but this time there had been a rain shower during the night and so I had to chip thick ice off the windscreen before we could depart. It was 06:00 when we pulled out onto the A1 and thereafter we took the A66 across to Brough and down to Kirkby Stephen and on to Sedbergh. We drove through fairly thick fog for the last 10 miles or so, but as we climbed up to the parking spot for our first summit we ran out of it. It was clear when we arrived at Garsdale Foot, SD699915. The curtains were drawn and all was quiet at the nearby farmhouse, so we kept as quiet as we could while we readied ourselves for the ascent of Baugh Fell G/NP-012.
We could see the fog in the valley starting to break up as we set out at 07:17 in reasonably bright conditions with a temperature of around 2C. We had hoped for frozen ground on this summit, but with the higher temperature, the ascent alongside Ringing Keld Gutter was seriously boggy. It was tiring going with the water laden ground and vegetation sucking at our boots with more or less every footstep. We kept to the tracks wherever we could, but detours to avoid the worst areas were necessary. My winterised schedule allowed 2 hours for the ascent and with the difficult conditions we reached the trig at Knoutberry Haw in 1 hour 47 minutes. Scanning across the summit plateau, we decided not to progress further to Tarn Rigg as there was a good couple of centimetres of standing water on the ground and walking the additional kilometre for an increase in height of just 2 metres wasn’t worthwhile. We found a couple of slightly drier spots close to the trig against the wall, which at least afforded us some protection from the cold wind that was blowing.
My first task was to temporarily remove a couple of flat stones from the top of the wall to place my kit and myself on. Once set up, the radio part was easy. Roger G0TRB was waiting for me on 144.333MHz and a steady run followed to put 15 contacts in the log. It was a pleasure to hook up with Alan MM1MPB from this one. After a chat with Nick G0HIK, the frequency went quiet so I moved to 70cms and using CW worked Reg G3WPF and Frank G3RMD in succession. Paul was already packing up when I was on the key, so after a couple of unsuccessful calls on SSB, I started to pack away at 10:35.
Paul’s first contact on 60m was another one with Paul G0HNW and Roger G0TRB followed. It was actually Don G0RQL who provided the spots for both 60m and 2m. 60m was again good around G and GW with reasonable signal strengths and Paul managed 14 contacts before he moved to 80m at around 08:50. Conditions were also reasonable on 80m and 9 contacts were made including Ken GM0AXY. At 10:20 the run ended and after a few more calls Paul decided to go QRT, leaving me to finish off on 70cms.
We were ready for the descent at 10:48, the stones that I had used to keep dry duly replaced on the wall. A steady pace was kept up to get us back to the car at 11:43 where we had a snack before moving the car across the valley to the single parking spot at SD697911 adjacent to the start of the track to our next summit, Aye Gill Pike G/NP-023.
It was 12:05 when we started our ascent and we were some 30 minutes ahead of schedule. However, I wondered how my winterised time allowance of 1 hour and 40 minutes for the ascent would stand up. Initially the track was quite steep and therefore well drained. As we gained height and the track flattened out, the ground became very damp and wet and presented the same issues as our previous summit such that we did not arrive at the summit until 13:37. In a cold brisk wind and beneath a mixture of sun and cloud, we set up at the summit trig. Paul used the trig to support his pole and I chose a small section of wall to take advantage of the shelter it provided and to support my pole. I noted the day had warmed up - 4C indeed.
At 13:54, Paul was first to get going at on this summit to find the ever-vigilant Roger G0TRB ready waiting on 60m. The skip length had noticeably lengthened from the morning and Paul’s third contact was a new country for him on the band, courtesy of Henry OZ3FD. The locals still got a look in as John G0TDM and Geoff G6MZX followed, in fact the spot came from Geoff. In a little over 35 minutes Paul had 17 contacts logged before moving to 80m around 14:30, our alerted time. Brian G8ADD managed to be first up on the band for the second summit running. Nigel G0RXA was second in line with Don G0NES making an appearance on the band, having just got home. Paul obliged with a brief move back to 60m to work Don, before returning to 80m to pick a fourth and final contact with Roger G0TRB. It was 15:00 when Paul went QRT.
On 2m SSB, my first call brought back Laurie G6XLL, very much to my surprise, with Roger G0TRB hot on his heels. Geoff G6MZX spotted me, but had to wait awhile as I worked through several contacts. When I worked John G0TDM he told me that Phil G4OBK/P was on Lord’s Seat G/LD-033 on FM, so I fired up the C520 and whip. Unfortunately Phil couldn’t make out my call when I called him, so I returned to the main station and worked him straight away, even though we were cross-polarised. This was my only S2S of the expedition. I moved back to SSB after working Phil and had a chat with Nick G0HIK who found that I was strongest when he beamed away from me - signals peaked at strength 9. With 11 contacts made on SSB and the S2S on FM, I decided to use up what power remained in my batteries on 2m FM and managed to add another 6 contacts to the log. My activation concluded with a contact on 70cms SSB with Mike G4BLH, just before my last power pack became unusable.
I started to pack away at 15:08 and we were ready for the descent by 15:22. While traversing a particularly damp section on our descent, I felt cold water enter my left boot. After three days of damp conditions the waterproofing of the fabric beneath the laces had become saturated. At least there were no more hills to climb and dry socks and footwear awaited me at the car, which we reached at 16:14. Our celebratory snack was a leisurely affair and we polished off more or less everything that Paul had packed, including those naughty things like cheese and biscuits. So much for taking off weight this trip!
Our return journey was straightforward – a 16:58 departure resulted in a 19:32 arrival at Stourbridge. Soup spiced with chillies was ready waiting for us, which warmed us nicely and we sat chatting about the activations we had carried out. I set out for home at 20:16 and arrived there at 21:40 – precisely on schedule, by fluke rather than judgement.
So another 6 NP summits activated which leaves us with just Mickle Fell G/NP-002 to complete the region. Plans have been in place to activate that summit for some time and we are hoping for decent weather on 30th December 2010, the date arranged with the Defence Estates.
Thanks to everyone for the contacts that we made and for the support that you provided. Particular thanks to G0TDM, G4BLH, G4OBK, G6LKB, G6ODU, G4OWG, G3RMD, G8ADD, G0RQL, GW4BVE, G6MZX and G0NES for the spots – quite a list. Hopefully we will manage an outing in the Lakes in early December, so keep an eye on the alerts page of SOTAwatch.
73, Gerald G4OIG
Good stuff Gerald, and evoking many happy memories of doing these hills with Jimmy and Liam in recent years.
I’ll tell you what though, I’ll never acuse you of being a purist again. What’s all this with not going all the way to the summit? I am with you though, on Hoove NP-024 we too operated from the trig point, by which there was a large depression in the ground for good shelter. Jimmy did continue the 200m or so to the true summit of the hill, but I elected not to bother I must admit.
Eyebrows were raised in this household at your admission to activating Tarn Rigg Hill NP-012 from the trig point on the adjacent lump Knoutberry Haw! Indeed, the true summit is only 2m higher than the trig point, but there is the matter of a 20m drop and then a 22m climb to negotiate to attain the summit from the trig! The 1:25000 OS maps are vague, offering only contour lines that place the vertical separation anywhere between 18m and 28m - and anything over 25m would put Knoutberry Haw outside of the AZ.
I might well have set up at the trig myself had I know this at the time - but would probably have bagged the summit first, as Jimmy would have insisted that he was going to anyway! However, I didn’t know this info, as I only had the OS 1:25000 sheet to go off. This suggests that Knoutberry Haw is, in all probability, in the AZ, but doesn’t guarantee it!
What is this food you two eat in your motel rooms at the end of the day? We tend to be ready for something hot and substantial by that time on a walking day - so when away from home, virtually always eat out, be it pub, curry house or fish & chips.
Which way are you going up Mickle Fell? The long (10km each way) walk that we did would have really suited deployment of mountain bikes. Enjoy.
(BTW, did you get to do NP-021 and NP-025 before they were “decommissioned”?).
Tom M1EYP
In reply to G4OIG:
A crackin’ read as usual Gerald, and some nice photos too. One thing that caught my eye and it might have been mentioned before but the wee wooden block Paul has to mount his mast against a trig point keeping it vertical (I noticed in the picture on Aye Gill Pike). Now that I am liking.
I remember Weatherspoons in Richmond before it was Weatherspoons, it used to be the Post Office in my day :slight_smile: I used to wander around Swaledale, that was my playground once upon a time. A real nice part of the world.
Iain, MM3WJZ
In reply to M1EYP:
Hi Tom,
Pleased that you enjoyed the report - it was a bit lengthy and I was rather late in getting it completed. I do try to fit as much detail without making it boring and I’m always surprised how many people say they look forward to reading it.
Actually Tom, I’ve never claimed to be a purist. Indeed, the highest points of quite a few summits that I have activated have not been achievable. How about the forest on White Top of Culreoch GM/SS-245 (believed now to have been cleared, but very much in place when I activated the summit in 2007) or Gamallt GW/NW-065? What about Tryfan GW/NW-006 - I certainly didn’t go up Adam and Eve before operating. Hill-baggers may spend hours tramping all over a summit to ensure they’ve trodden on the highest spot, but that’s their perogative, not mine. :slight_smile:
In the case of Baugh Fell G/NP-012, it seems likely that Knoutberry Haw was considered to be the highest point when the trig was constructed. Presumably Tarn Rigg became the highest point as surveying techniques improved. I would say that the suggested 20m drop did not appear to be that great on the ground - had there been any doubt in our minds, then we would have continued to the currently accepted highest point. Maybe someone can check that out with a GPS when they next activate the hill. I’m quite happy to scrub the activation and re-do it if it is proved beyond doubt that Knoutberry Haw is outside of the AZ.
Paul usually prepares the scoff - soup, excellent seeded “buns” with chicken, pastrami and ham filling, salad, snacks, etc, etc. Suits us down to the ground - no need for mega-calories a la Lymm truckstop. Quite frankly, on the first night we are usually too tired to be bothered about going out - I’ve usually been up since 02:30 or even earlier!
The southern route, parking at the cattle grid on the B road. There are now only 2 permitted routes on Mickle Fell. The long walk in that you did is no longer acceptable to the military. I’ve put a note on the summit page.
Yes, both on their last day… and dear old Lovely Seat G/NP-030. Such a shame that one.
73, Gerald G4OIG
In reply to MM3WJZ:
Hi Iain,
Many thanks for the comments. They were an enjoyable group of summits in some beautiful countryside - I guess most are now under the white stuff. How fortunate we were with the weather!
You’ve reminded me that I still need to make a block for using the pole at a trig point. Paul uses it with webbing straps and rarely has an issue with stability.
73, Gerald G4OIG
Oops, I forgot about Lovely Seat - but that was a recent deletion anyway, so assumed you would have definitely activated that one.
There is no worry about NP-012. Knoutberry Haw’s prominence is listed as 20m, which means that Tarn Rigg Hill’s rise from the saddle with it must be 22m. So the trig point is definitely in the AZ.
Shame to hear that the route I did on Mickle Fell is no longer permitted. It was a rather enjoyable one.
Tom M1EYP
In reply to G4OIG:
Hi Gerald, just a minor point re your access arrangements posting. When we did NP-002 last year we used the northern route i.e. crossing Maize Beck, and found that we were unable to get mobile phone coverage at Cow Green Reservoir or for that matter in Teesdale as we approached. Consequently we didn’t manage to ring the guard house as required. We met other people up there who said the same, they’d intended to ring when they entered the controlled area but found they couldn’t. I guess the best thing to do is to ring well before you get there and give your ETA, and don’t forget to ring when you leave or they may feel obliged to send out a search party.
Rick
Back when we did it (2006), there were published public access days. If you went on one of those days, you didn’t need to arrange individual permission. There were other “non-firing” days, but you did need to arrange individual permission on these. I recall that we used one of the open access weekends, but also recall that I did make a phone call to the office - probably to double check the access arrangements.
Good info on the summit page Gerald. Now what about some access info for the MW-032 page? :wink:
Tom M1EYP
In reply to M0RCP:
Thanks for the heads up Rick. I did check the O2 coverage map and I think we can get in quite close to the parking spot before we need to phone the guard room. I wouldn’t think of accessing the land without letting them know - they have been so good with the arrangements. All we need now is decent weather!
In reply to M1EYP:
GW/MW-032 is still in hand I’m afraid Tom. We must get that one sorted - it’s frustrating to have a summit so near outstanding and stopping us completing GW.
73, Gerald G4OIG
#10
In reply to M1EYP:
Thanks for the further comment Tom. We’d not have thought twice about walking the extra kilometre had conditions on the ground not been so dire making it slow going. Must say I’m surprised that the prominence is 20m as it didn’t look anywhere near half the height of the 39m rise between the parking spot and summit for Hoove NP-024.
73, Gerald G4OIG
#11
In reply to G4OIG:
Hi Gerald,
In one of my rare visits to the reflector, I saw your report. As Tom says it brings memories as these are so familiar. Being able to visualize makes it even better. It was quite a workup with all that wet ground.
Aye Gill Pike is quite hard for a 2-pointer as is Hoove, which is far from being one of my favourites. I see for Aye Gill, you walked up the west side of the plantation whereas I always go up the east side of it. It’s a bit shorter - the farmer is a friend. The wall had side-slid into a convenient seat with back rest. Maybe you made use of that but depends on the wind.
Your route for Baugh Fell from west was interesting. Again it’s not an easy one. I tried from the east - Grisedale but wasn’t happy with that. All other times I’ve gone straight up the side but it still takes nearly an hour. Nice to have walls to cower behind.
I hope you liked 9-Stds. There’s been a lot of hard work up there in recent years.
Rogan’s is, as you say, a decent walk though long. Phil G4OBK had some gamekeeper agro up there a couple of years ago. I once did it on a bike; down the icy track with numb hands in moonlight.
Enjoy Mickle - my favourite hill for decades now bar none, though most cannot see why. 90% of the time I go from the north but Maize can be awkward. My son and I might have drowned there in 1986; it was close. At low rainfall times, it’s easy enough to ford it. I was all set to do it 5 weeks ago but my XYL was hospitalized that day and will be convalesing for some time to come.
Thanks for making the effort to come all the way up here to activate these NP’s. Well done to you es Paul.
73, John.
#12
In reply to G4YSS:
Many thanks for the interesting comments John. They are a lovely set of summits without any hassle in respect of parking or access. As we stayed over, the effort was spread over the three days… and neither of us ached the day after. It is far more pleasant doing it that way than rushing from summit to summit - done that and have a wardrobe full of teeshirts!
We selected the southern route for Mickle Fell on account of uncertainty in respect of the beck - sounds like we made a good decision, though we are hoping that the ground is frozen as it will make access much easier for us. At least we shouldn’t get lost as we have a fence to follow.
Sorry to hear that your good lady is unwell. I hope that she is now on the road to recovery and will soon be back to full health. Hopefully you’ll be able to find time to get up some summits over the winter.
73, Gerald G4OIG
#13
In reply to MM3WJZ:
the wee
it vertical
Hi Iain
Very observant of you! That’s my “Trig Jig” - I’ve been using it for several years now, very effective. A notch one side to locate the pole, and the other side chamfered to suit the slope of the standard “Hottine” trig point. I’ve found the best position for the (quick release ratchet)strap is just below the jig. Set it up on the leeward side of the trig, so the wind blows the base of the pole harder against the trig and put the pole side leg of the wire antenna out first so the tension does the same. In really rough conditions or with a VHF beam on I sit with my back to the trig against the pole for extra stability, (not very comfortable)or place a big stone against the pole to counter sideways movement. The original concept had another (thinner) jig and strap at lower level, but that proved to be unnescesarily complex.
A refinement might be some non-slip “dash mat” material or similar on the face that contacts the trig. Must get round to trying it one day.
Everyone should have one! Wonder if I could sell the idea to Richard 'CWI :wink:
Enjoy the snow
73 de Paul G4MD
#14
In reply to M1EYP:
Glad we got that one sorted out (not that there was ever any doubt in my mind). Despite my new-found enthusiasm for visiting previously activated summits, I have no desire to return to this bog-fest in the near future…
73 de Paul G4MD
#15
In reply to G4MD:
Could you let us know some dimensions (or the angle between the two faces) so that we don’t have to go up a hill to measure a trig first please.
Colin G8TMV
#16
In reply to G8TMV:
please.
Hi Colin
Sorry about the slow reply, just catching up after a hard week…
I made mine out of a piece of 69 by 38 fin CLS, 120mm long, although 94 fin would be better, the narrower timber not quite giving verticality over the length of the bottom section of a 6.7m SOTA pole. To fit the slope of the trig, you need a 5mm chamfer over the 38mm face. The notch for the pole is 25mm deep to it’s apex, but it may be more elegant and effective to put in a semicircular recess to suit the pole diameter.I can feel a Mk 2 coming on…
Hope that gives some pointers!
73 de Paul G4MD
