I’ve received a few messages saying the 6m/10m challenge page is not scoring properly. I have just entered my log for 10m and it worked for me. That statistically massive sample of 1 is not relevant. If I’d only had one report I’d assume usage error but I have had enough reports to convince something is amiss. I can’t see what it is yet!
So if you have a problem, just post the date, summit ref. and callsign used and I can get on and fix any gremlins.
Did you activate a summit on 14 Nov 15? At 16 Aug 15 my 6 &10 m challenge ‘Callsign’ count was 105 and the multiplier score was 18.
On 14 Nov 15, I activated 2 summits Mt Coree VK1/AC-023 and Mt Ginini VK1/AC-008 both of which were not activated in the 1st round. Mt Coree on 6 and 10m and Mt Ginini on 6m only. After entering my activator log and running the report the multiplier didn’t change, I was expecting the multiplier to increase by 2 to 20.
On Tuesday 17 Nov 15 I activated Mt Mundoonen on 6 and 10m. After entering the log and running the report the multiplier advanced by 1 to 19 as expected.
Just guessing here, but perhaps the date change from 15/11 to 14/11 is not yet reflected in the code that selects and counts unique callsigns and summits activated.
Hi Andy,
On 12/11/2015 i activated PA/PA-003 . I make 2 QSO’s on 28.030- (gmt12.51) with AC1Z and K1BV (12.53).
These QSO’s are not in the 6//10m scoring.
Thanks for help!
Working fine for me with my 10m chaser enties over the last few days (17th, 18th, 19th, & 20th), can’t say if 6m data is a problem as I haven’t had any contacts yet in this second period or if the activator side is working, but as far as I can see, the 10m chaser side seems fine.
OK, with the various reports I’ve found the typo. I’ll upload a fix later in the week. I’m still working through emails that need a reply etc. I received when on vacation. I didn’t really want to but I fired up my work laptop earlier and there were a few hundred emails that needed sorting through. About 30 important ones and lots of dross. At least I’ll be up to speed when I return.
So the important point for everyone is that as long as you have entered the QSO into the database then you will get the points after I upload a new version of the code.
