Hi all,
this morning i´m qrv from DM/BW-149 es Bw-197.149 at abt. 0800utc and 197 at abt. 1000utc.i will beginn at 3.558-cw and after on 10.118-cw.And then after a short break i will call on 7.032-cw and 7.115/7.068-ssb.The reason is , that i changed after 30m to my new homebrew-transceiver.This procedure agn at next activations till i finished and have time for my other bandmodules.On the first summit i plan to use a simple 30m-longwire with radials and on the second summit i will use a fullsize double-zepp antenna.so maybe the last activation starts a bit later.yesterday evening i checked with Ralf DH3IAJ the signal and audio of my rig on ssb and it seems to be ok with abt. 15watts and 15:1db compression in ssb.but have not time to fix the frequency-counter,so maybe the qrg´s are 1khz up or down
to the spotted start-qrg´s .
hpe cu u tmrw…vy 73 Klaus DF2GN
Mike GW0DSP : Hi Mike , you asked in flick´r for the building time of my trx.-> abt. 6 weeks without bandmodules.but this one is not my first homemade-trx
