hi friends,
i will say thank you to all chasers ! today i finished my activation on DM/BW-079
"Ellbachkopf" with 109 qso´s in my log . and that with low power on hf only. no real qrp , but only 10watts on cw and abt. 15watts on ssb with my homebrew rig. i think the speech-compressor in it , is very usefull. i never heared my signal , but most mod-reports are ok ! antenna today again the 2 x 18.5m sym. dipol with z-match and feedpoint only in abt. 6m . started todays activation after qrl, because this summit is not far away from my working-place. at 1400utc i began with a “qrl?” on 7032-cw and roy ´ssh came back to my call with nice sigs. and then the “zoo” started,hi. after the first 30 minutes i logged 41 stations and to come down a bit, i started with cq qrs . and i think , compared to other activations , many qrs stations comes back to my slow calls. at 1444 i had 55 chasers in my log.
14:00z G4SSH/A 7MHz CW
14:01z G0HIO 7MHz CW
14:01z F8BBL 7MHz CW
14:02z OE6DK 7MHz CW
14:03z F5AKL 7MHz CW
14:03z ON4ON 7MHz CW
14:04z F6CEL 7MHz CW
14:04z DL4FCK 7MHz CW
14:05z DL1FU 7MHz CW
14:06z DL4ALI 7MHz CW
14:07z G4OBK 7MHz CW
14:08z F8DGF 7MHz CW
14:08z G3HKO 7MHz CW
14:09z G3TJE 7MHz CW
14:10z HB9AFI 7MHz CW
14:10z F5RKL 7MHz CW
14:11z HB9AGH 7MHz CW
14:12z G4CMQ 7MHz CW
14:12z I2YWR 7MHz CW
14:13z EI7CC 7MHz CW
14:14z DL6FAX 7MHz CW
14:15z EI6AK 7MHz CW
14:15z GM0AXY 7MHz CW
14:16z F5IQJ 7MHz CW
14:16z DJ5AV 7MHz CW
14:17z G0AOD 7MHz CW
14:18z HB9DAX 7MHz CW
14:18z OE6WTD 7MHz CW
14:19z DF5WA 7MHz CW
14:20z GW0DSP 7MHz CW
14:20z OK2BDF 7MHz CW
14:21z G4ZIB 7MHz CW
14:22z DL9GTI 7MHz CW
14:22z DL4FDM 7MHz CW
14:23z HA3FZ 7MHz CW
14:24z G0NES 7MHz CW
14:25z F8ADJ 7MHz CW
14:26z G4WSX 7MHz CW
14:27z M1EYP 7MHz CW
14:29z DL0VK/P 7MHz CW
14:30z DL3HSC 7MHz CW
14:31z M0COP 7MHz CW
14:33z DJ0GD 7MHz CW
14:34z EI8DL 7MHz CW
14:36z OE3KAB 7MHz CW
14:37z I1EEW 7MHz CW
14:37z G4BLH 7MHz CW
14:39z DL7RAG 7MHz CW
14:40z OK1HRA 7MHz CW
14:40z DL4HSI 7MHz CW
14:41z DL2DXA 7MHz CW
14:42z F6GEO 7MHz CW
14:43z F6ENO 7MHz CW
14:44z GW3LNR 7MHz CW
14:44z DJ4EY 7MHz CW
then i qsy´ed to 7096 as spotted to do the ssb-part , but on that qrg big sigs
from other stations. so i moved a bit up and call cq. OE3KAB was the first and followed from the regulars GW0VMZ,2E0HJD,F8BBL es much other nice ssb-chasers. but ssb in the afternoon , evening hours is very difficult due to qrm. but all in all 17 ssb´ers in 14 minutes…
14:50z OE3KAB 7MHz SSB
14:50z F8BBL 7MHz SSB
14:51z GW0VMZ 7MHz SSB
14:52z 2E0HJD 7MHz SSB
14:52z I1EEW 7MHz SSB
14:53z OE5PLN 7MHz SSB
14:53z GM4YMM 7MHz SSB
14:54z GM4FAM 7MHz SSB
14:55z 2E0KPO 7MHz SSB
14:55z M3PXW 7MHz SSB
14:56z G0RQL 7MHz SSB
14:58z M0JDK 7MHz SSB
14:59z ON6DSL 7MHz SSB
15:01z DL9SUB 7MHz SSB
15:02z G4WHA 7MHz SSB
15:03z G6DTN 7MHz SSB
15:04z 2E0NBR 7MHz SSB
after that i qsy´ed to 3558khc-cw, a new regular band from me witl allmost good sigs from HB9. but also had a few callers from G ! on 80m i work mostly with only 5 watt real qrp, think antenna working there UFB. and 19 qso in the 16mins on this band.
15:07z HB9BYZ 3.5MHz CW
15:07z OE3KAB 3.5MHz CW
15:08z OQ1C 3.5MHz CW
15:08z DL4FCK 3.5MHz CW
15:09z F6ENO 3.5MHz CW
15:10z DJ5AV 3.5MHz CW
15:10z HB9DAX 3.5MHz CW
15:12z HB9CKV 3.5MHz CW
15:13z DL8DXL 3.5MHz CW
15:13z HB9AAQ 3.5MHz CW
15:14z HB9CMI 3.5MHz CW
15:15z HB9AGH 3.5MHz CW
15:16z DL4FDM 3.5MHz CW
15:18z PA0FBI 3.5MHz CW
15:19z G3CWI 3.5MHz CW
15:21z G3KYF 3.5MHz CW
15:22z F6CEL 3.5MHz CW
15:23z G3HKO 3.5MHz CW
15:23z DJ4BA 3.5MHz CW
and after 80m i going back to 40m 7032 to make the last calls , like most activations from me. first one was G3VQO with good sigs and followed by 16 chasers from 1527 to 1546utc. G4CPA was the last one in the log. so today was my first activation with 100+ qso´s . and that makes me happy,hi . my luck today, temperatures are ok with no wind.
15:27z G3VQO 7MHz CW
15:28z DL8USA 7MHz CW
15:29z OH3GZ 7MHz CW
15:30z SP5CGN 7MHz CW
15:31z G4OBK 7MHz CW
15:33z F6ACV 7MHz CW
15:34z F4EUN 7MHz CW
15:35z DL4VM 7MHz CW
15:37z GM4FAM 7MHz CW
15:39z G0BPU 7MHz CW
15:40z RX4HJ 7MHz CW
15:40z GM0IFM 7MHz CW
15:42z G3CWI 7MHz CW
15:43z DL6KVA 7MHz CW
15:44z OE5WLL 7MHz CW
15:45z S51CL 7MHz CW
15:46z G4CPA 7MHz CW
but what will activators do in winter with -0C° or colder ? chasers can help with short qso´s with only callsign es rapport. ragchewing we can do again in summer most times i have time to say hello or more, but in comming winter i will do more contest-style in my activations. but thats no problem with qrs, the also a qrs-qso can be fast with only call es rprt . i don´t want to reduce my sota to only 1 band or cw-only, to give all chasers the same chance to work me on the summits. but more bands and modes = more activation time …
by the way. since my first activation at 27.Feb on Mooswaldkopf to now i activated 289 summits and done 7813qso´s on hf and meet many new friends all over europe, and thats fine :o)
for all who wonder about the many activations :
i reduced my hamradio-hobby to sota-only since a few months. i have enough fun with it, and not many time for other things in hamradio. uuhhhh, i need only abt. 100 points to get my shack-slot status. i hope this year i reach it. but chances to get s2s in winter is not so big. also my other new hobby is searching geocaches with my yl ( want´s also a bit from me ) . marathon is ending for me now, due to problems with my knees after abt. 20km/30km of running, so only hobby-running anymore. but i like it more to run for my self as against the clock. so i can better enjoy the nature on my trips in black-forest
so again thank you for that nice activation today and hope cuagn on the summits,
Klaus DF2GN/P
