2 meter band
I am thinking about doing 2 meters. Which frequency would you suggest?
In reply to MW6GWR:
2m FM start on 145.500 with a planned QSY to something like 145.425; check for use before QSY.
2m ssb start on 144.300 and go to 144.280 or 320; both are used a fair bit but 2m ssb is so sparse that you can almost guarantee one will be free.
Good luck.
Rod
In reply to MW6GWR:
Avoid the frequencies where Nets start Txing on your QRG in the middle of an activation, then pretend they can’t hear you (even if you’re running 50 Watts up a collinear) when they’re politely asked to QSY, despite the fact you’re 5/9++ on Uranus and you’ve been working a pile-up for 3 hours solid…
73 Mike
2E0YYY
In reply to 2E0YYY:
You leave yourself open to abuse…
Of all the planets to think of!
In reply to G1STQ:
Yes, on Uranus and working a Pile-up…
Must be the result of too long spent sat on cold damp ground!
Jonathan
2E0CTW
In reply to 2E0CTW:
In reply to G1STQ:
73 Mike
2E0YYY
In reply to M0JLA:
Thanks Rod the radio i have got is the alinco DJ-195 for 2 meter so i think it only FM.
Ricky
MW6GWR
In reply to 2E0YYY:
Thanks for the tip Mike.
Ricky
MW6GWR
In reply to MW6GWR:
Ricky - keep an eye on Spots and see what frequencies other activators are using and you’ll soon build up a small list.
Write this in your log book and you can’t forget when up to your waist in snow/mud/rain/sheep doodah or anything else. Works a treat and as you start to use more bands/modes, just keep updating your list.
It can be a shock just what you can and do forget when cold up on a big hill in a blizzard.
Have fun!
John
In reply to G1SSTQ:
thanks for the tip John i will do that
Ricky
MW6GWR
