10G SOTA for under a tenner
Anyone wanting to have a go at 10GHz from SOTA hills can try receiving signals very cheaply. Modern dual-band satellite LNBs are basically 10GHz receiver converters and many are stable enough for SSB reception. All that is needed is a suitable scanner or other RX to attach to the LNB to get a very sensitive 10GHz receiver. Alternatively a mixer could be made to convert the output to 70cm.
The UK microwave group’s series of contests/activity days would be an ideal time to test such an arrangement. One-way contacts “count” for this contest so even without a 10GHz transmitter, you would be in demand for tests. You would need some sort of talk-back, 2m SSB is popular.
Advice and tips on this approach are available at:
http://groups.yahoo.com/group/ukmicrowaves/
Richard
G3CWI
In reply to G3CWI:
Hi Richard, I have not yet got on to the Yahoo group as awaiting approval so I haven’t seen anything there, but it occurs to me that if a Blue Cap LNB can be converted for TX maybe a twin LNB could be modified for TX on one side and RX on the other. Hopefully this is the case as I have several kicking around in the garage from the old analog days.
73 Steve GW7AAV
In reply to GW7AAV:
Steve
A few ideas of what might be done are here:
http://www.g4hjw.metahusky.net/
I don’t think LNBs need any modifications for use as an RX converter - but they do need to be powered up correctly.
This may help:
http://ea4eoz.ure.es/lnb.html
He claims SSB is not possible - but he is wrong. Some LNBs are stable enough for SSB.
When you get on the microwave group try searching the message archives - or just ask.
Richard
G3CWI
In reply to G3CWI:
Tnx Richard, I now have little light reading for the night shift while we are all broke down ;0D
Steve
In reply to G3CWI:
Here it seems to be popular to use Mont Blanc as a reflector for these microwave signals. I found information on this kind of beacon
http://f1uri.free.fr/beacon.htm
73, Jaakko OH7BF/F5VGL
